Old 03-10-2005, 10:42 AM
c420has c420has is offline
Send a message via AIM to c420has
Angry Starting Problems
Can anyone please help me before I go crazy and blow up my car. I have a 1997 pontiac 3.8L V6. I am having problems starting my car. I know that the starter is fine because when I jump the starter it turns over. It started acting up and all I did was tighten the positive wire to my battery and it started up fine and worked for a while but then stopped working. I just replaced the igniton switch because I figured that it was bad, in which it was, but that still didn't solve my problem. I am getting power to the ignition switch and my turn signals, but I am getting any power at all to my dash. My horn works, radio, headlights, and everything else, but for some reason there is no power going to my dash. Nothing on my dash works at all, no pre-engine lights or anything, not even a power reading of the battery. The car doesn't turn over at all when ever I try to start it with the key. I replaced the battery thinking maybe it could have something to do with it but, still no help to my problem. Can someone please help.
Old 03-10-2005, 12:00 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Starting Problems
You have checked all your fuse's right?
Also welcome to the forum.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 03-10-2005, 12:45 PM
volkerc's Avatar
volkerc volkerc is offline
check if you accidentally pulled a wire under the dash, when doing your work, would be my guess.
Old 03-10-2005, 12:49 PM
yeah all the fuses are fine
Old 03-10-2005, 12:50 PM
This was happening before I pulled anything from under the dash. I have checked everything under the dash twice and it is all connected
Old 03-10-2005, 03:54 PM
volkerc's Avatar
Re: Re: Starting Problems
security system maybe?
Old 03-13-2005, 03:13 PM
99onI95's Avatar
99onI95 99onI95 is offline
If its the same problem I've been having it's your key. The two metal prongs on each side are worn and not registering with the computer. Get a new ignition key.
