Old 03-10-2005, 09:16 AM
kklagge kklagge is offline
E brake light
I recently had the E brakes redone (totally worn & a bad cable). Since having them redone when I set the brake the light in the dash flashes on and off (never did that before). Does anyone know if that has one of those reset procedures like the change oil light does?
Old 03-10-2005, 07:28 PM
jumpingjack66's Avatar
jumpingjack66 jumpingjack66 is offline
Send a message via Yahoo to jumpingjack66
Re: E brake light
no it is not.. mine blinks when applied and if you drive off with it applied you should haver a chime go off.. allthough at that point your e brake is already trashed...jj
2000 Silverado Victory Red, standard cab, short bed, short wheelbase, 4X4, 4.8L, 5 speed, 4:10 locking rear diff, K&n FIPK, Ryno lined all the way over bed rail, heavy half suspension,factory skid plates,Fog lights, BFG 285/75/16 A/T's, dashmat, Stealth Radar.
lots of special options some installed by me!
1980 Suzuki GS1100E Super fast
Old 03-11-2005, 12:07 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: E brake light
If it's just random flashing, and not a pattern, the cable might not be tight enough and is letting the pedal fall a bit, turning the light on.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
