| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
![]() Join Date: Apr 2004
What IS the tensioner pulley?
And should it be replaced after 100K?
Soon going to have the timing belt, tensioner, and water pump changed out. Are there other things I should do while in there? i.e. camshaft/crankshaft seals, etc? Not having any leaks or noises - just want to save labor later. Thanks
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
#2 | |
It's a small pulley that prevents the T-belt from slipping (teeth) by applying force on the belt. The tensioner pulley is attached to the hydraulic pusher / pushrod that uses engine oil pressure to 'pump up'. The pushrod is what gets weak causing the tensioner pulley to not do it's job.
G/luck Joel
2016 Subaru Forester 2.5i base CVT 2016 Nissan Quest SV |
#3 | ||
Re: What IS the tensioner pulley?
Ok, if I'm understanding right, the "timing belt tensioner" IS the Tensioner pulley? Do I have that right? And I'm understanding that I should also replace the pushrod? Thanks for your help!
#4 | |
No, the timing belt tensioner and the timing belt idler pulley are two different parts. Replace the tensioner. The pulleys last forever and are expensive.
#5 | ||
Great, ok - that sounds good. Sorry for repeating myself, but what about the Pushrod? As you can see, I've never been in there myself to know exactly what this part is. Thanx!
#6 | |
![]() Join Date: Nov 2004
Unless there is a second definition, a pushrod is a pencil sized rod that rest on the camshaft, and push the rockers which open the valves.
I don't see how changing the pushrods has anything to do with timing. They are usually cleaned/replaced when performing major top-end work. Steve |
#7 | ||
Fantastic, thank you! And thanks to everyone, y'all answered my questions.
#8 | |
Good luck with the work
![]() You might want to pick up a front crank seal and replace it when you take off the front cover. If you don't, and it starts to leak after you put everything back together, you'll be kicking yourself for not replacing that often-overlooked $5 part. It's also a wise idea to give all the pulleys (A/C, alternator etc) a couple good spins while everything is dissasembled up front. Make sure there is no bearing stiffness, noise etc. Give your rad hoses a good squeeze, make sure they are not squishy or cracking. Look closely at your electrical contacts (at the battery, all grounds) and clean up as required. Usually when I undertake a larger project, I'll drop some oil, or spray a bit of wd-40 on most ground contacts to prevent corrosion, and spray linkages (throttle cable linkages etc) with the same. I've always found small, overlooked maintenance like this often avoids intermittent silly headaches later. Steve |
#9 | |||
The T-belt tensioner assembly has it's own pulley, as does the T-belt idler. You are correct in that the hydraulic tensioner is typically what goes first. Quote:
The T-belt tensioner assemby contains a small hydraulic piston, or pushrod. G/luck! Joel --------------------------------------------------------------------------------
