Starting problem - 1991 Bravada - 4.3
I'm having an intermittent starting problem. Most of the time, it starts OK. But at the worst possible times, it won't start with 10 or 15 tries. At these times, if I let it set 15 or 20 minutes, it will finally start. It's showing no codes. All the ignition parts are now new. The injectors are pumping gas while it's cranking. Starting fluid does no good. Any suggestions as to what I might try?
I am having a problem that sound a lot like yours. The first place to test would be for spark. Then I would go to the fuel pressure. If you are getting spark the fuel pressure should be between 55-61 psi. Test this when you are getting a no start. I am thinking my problem lies in the fuel pump not giving enough pressure for the injetors to fire the proper amount of fuel. Pending any other possibilites from responses today I will be changing the fuel pump in the next few days and will let you know if that works. When I was getting a no start the pressure was anywhere from 50-54 and most of the time turning right over on the first try at 54 but oanything less and it is taking me several turns to get her started. This is all assuming you have the vortec engine. Let me know how you do and I will let you know my outcome also.
Re: Starting problem - 1991 Bravada - 4.3
Even though my engine isn't a vortec (has round air cleaner), it sounds as though our problems are very similar, as you mentioned. At what point in the system do you hook up to measure the fuel pressure? Does it take a special fuel gauge? Regards
Re: Re: Starting problem - 1991 Bravada - 4.3
