Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 03-10-2005, 06:35 AM
furbrother furbrother is offline
Review on Header
Ok I went against some of you guys opinions and bought my header on ebay for $150.. I recieved the item in one week, did all the install myself (no shop around wanted to touch it and the one that would wanted $200). Its not that hard of an install outside of getting the bolts off (note this review is for 97-2001 models). The header that comes in the kit is missed drill on the bottom right and left, should be exspected from an aftermarket part. After I redrilled them correctly, they went on smoothly (note you will need to loosen the power steering wheel and remove the rad fan). The kit came with all the gaskets, bolts, down piping, and a new fake cat, also proper holes for your o2 sensors. NOw if you live in a state that requires an emissons test I suggest against buying it, for you dont have a cat anymore (looks like a cat from the outside but its hollowed out). Performace is probably what everyone wants to know. There was a def boost in power through out! I can chirp my tires in both 1st and 2nd now. Outside of the miss drill the headers are well worth the money! They are a 4-2-1 set up! Note performace might be different: my set up is as followed: CAI, a true custom cat back (2.25 piping strieght piping all the way back), no cat, and new headers.
Old 04-02-2005, 02:11 AM
Tib2004 Tib2004 is offline
Banned
Send a message via AIM to Tib2004 Send a message via Yahoo to Tib2004
Re: Review on Header
hey guys,
i also bought some headers off ebay, theyre OBX racing headers.Were they a good buy? I just didn't have the money to go elsewhere. I paid 285 bucks.
Dyno tested and proven
Direct bolt-on without modification
T-304 stainless steel mandrel bend for ultra fast flow.
CNC machine flanges with TIG and MIG welded construction
Utilizes factory 02 sensor position
Gaskets and hardware included
Lifetime warranty from manufacturer defects.
Old 04-02-2005, 02:29 AM
Re: Re: Review on Header
I looked on ebay for your header and it basically is the same one I got.. it works great and I have had no problem outside of an o2 sensor dying (but i am perrty sure that was my fault). Only thing I warn you is that the header might not be drilled properly, but nothing that a basic drill cant fix. Good luck and trust me you will be a whole lot happier!
Old 04-02-2005, 12:09 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
good luck with the headers... the installs on the i4s only take a few min
almost that time
my sig made mommies cry, thats why i had to change it..
Old 04-03-2005, 04:21 PM
free2roamaz free2roamaz is offline
Send a message via AIM to free2roamaz
Didnt think I should make a new thread for this question, but I was just wondering if a bigger throttle body is worth investing in if I dont have exhaust? Also, can duel catbacks be installed on the 01 Tib, i4 w/out spending a shit load of cash?
Old 04-03-2005, 07:02 PM
Tib Guy
a bbtb is always good for more air flow to your intake manifold
almost that time
Old 04-03-2005, 10:16 PM
I know the dual looks cool, but for performance wise it is a waste to go to a dual. The whole point of exhaust system is to get rid of the exhaust fumes as quick as possible. When i went to have my custom exhaust done I wanted to go with the dual exhaust too, but there is a box on the left side that your not suppose to get heat by, so i went away from that. So instead I had them increase the pipe size, very little bend at all, no cat, and a sound that makes people look. BUt for enough money u can get it done, just not worth it honestly!
Old 04-22-2005, 11:34 PM
Banned
hey furbrother,
did anything happen with your check engine light? I'm about to install these headers and I don't know what to expect, also check out thread labeled " working on boosting horsepower" that i started, i have some specific questions on there regarding the header install and what to do afterwards, i could really use your experience to compare to mine.
Old 04-23-2005, 12:22 AM
Red2.0Tib Red2.0Tib is offline
Send a message via AIM to Red2.0Tib
Ya, the header install on any year I4 Tib is pretty straightforward and easy. I found my install to be easy, but overall I was disappointed with the gains I had going NA on my BetaII. I have since removed all my NA stuff and am going FI. As far as a BBTB, well you won't really feel much in the way of power, maybe some crisper throttle response.
Old 04-23-2005, 02:45 AM
Tib Guy
HAHAHAHHAHAHAHAHAHAHHAHAAHAHAHAHAHHAAHHAHAHAHAHAHH AHHAHAHAHAHHAHAHAHAHAHAHHAHAAHAHAHAHAHHAAHHAHAHAHA HAHHAHHAHAHAHAHHAHAHAHAHAHAHHAHAAHAHAHAHAHHAAHHAHA HAHAHAHHAHHAHAHAHAHHAHAHAHAHAHAHHAHAAHAHAHAHAHHAAH HAHAHAHAHAHHAHHAHAHAHAHHAHAHAHAHAHAHHAHAAHAHAHAHAH HAAHHAHAHAHAHAHHAHHAHAHAHAHHAHAHAHAHAHAHHAHAAHAHAH AHAHHAAHHAHAHAHAHAHHAHHAHAHAHAHHAHAHAHAHAHAHHAHAAH AHAHAHAHHAAHHAHAHAHAHAHHAHHAHAHAHAHHAHAHAHAHAHAHHA HAAHAHAHAHAHHAAHHAHAHAHAHAHHAHHAHAHAHAHHAHAHAHAHAH AHHAHAAHAHAHAHAHHAAHHAHAHAHAHAHHAHHAHAHAHAHHAHAHAH AHAHAHHAHAAHAHAHAHAHHAAHHAHAHAHAHAHHAHHAHAHAHAHHAH AHAHAHAHAHHAHAAHAHAHAHAHHAAHHAHAHAHAHAHHAHHAHAHAHA HHAHAHAHAHAHAHHAHAAHAHAHAHAHHAAHHAHAHAHAHAHHAHHAHA HAHAHHAHAHAHAHAHAHHAHAAHAHAHAHAHHAAHHAHAHAHAHAHHAH HA....ha?!!
you gotta be kidding me....
almost that time
Old 04-23-2005, 10:09 AM
BigTDawg BigTDawg is offline
Send a message via AIM to BigTDawg
ahahha so how much money did you waste by doing that?
Old 04-23-2005, 05:02 PM
Ya ya nisco, laugh it up, O and see ya at S3
Old 04-23-2005, 09:31 PM
Tib Guy
Re: Re: Re: Review on Header
i can only laugh for so long.. cause youll be boostin.. and ill be... uhhh .... not
almost that time
Old 04-23-2005, 10:00 PM
Re: Re: Re: Re: Review on Header
At least yours will look sexy Mine is going to be rolling on stock 17's no kit, and a nice dent in the hood from some FREAKING MORON!!!!!!!!!
Old 04-24-2005, 02:47 AM
Tib Guy
Re: Re: Re: Re: Re: Review on Header
sleeeeeeeeeepppppppeeeeeeeerrrrrrrrrrrrr
almost that time
