Old 03-10-2005, 06:05 AM
konan konan is offline
Question Runs on 3 cylinders when cold
I have a 95 S-10. A couple days ago I started it up in the morning, runs on 3 cylinders. Get on the road, after about 10 minutes it starts running normal, misfires here and there. Same thing next day. The only thing I had done was the oil changed the day before this started happening. Checked for loose s/p wires, they seem ok. Fouled plugs? Any ideas?
Old 03-10-2005, 09:20 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Runs on 3 cylinders when cold
Could be bad plugs, bad CPI unit, bad wires, bad cap and or rotor..
Old 03-10-2005, 12:08 PM
kenyonja2007's Avatar
kenyonja2007 kenyonja2007 is offline
Send a message via AIM to kenyonja2007
When my head gasket went and my head was cracked my truck ran on 3 out of the 4 cylinders, but it was definitely not as long as 10 minues, probably about 30 seconds. If my oil pressure guage is correct, everytime I change my oil the pressure is a bit higher for a few days (no, it doesn't leak), so maybe yours is the same way and your boost in oil pressure caused something to fail. Just a guess.
1994 Chevrolet S10
2.2L, 2WD, Auto, Long Bed, more here
Brakes are a good thing
Old 03-10-2005, 06:41 PM
ALMB~Nova ALMB~Nova is offline
Check to see if you may have knocked any wires off of any sensors or maybe a vaccum line. start off simple. any codes??
1985 V8 S10
1974 NOMEGA (Chevy-Olds hybrid 1/2 nova 1/2 omega)
Old 03-15-2005, 03:53 PM
jbrisson jbrisson is offline
Send a message via ICQ to jbrisson
I beleive the 95's were HEI weren't they?
I had a similar problem, ended up being the of the coil packs starting to fail.
1996 Chevy S-10 STD bed, STD Cab / 2.2 4cyl Stock 5 spd.
123k
"Ultra-Lux" Manual window / door lock actuators.
Sony CDX-M9900 Head / Sony XM-2150GSX
Kicker 03CVR10 10"x2
Boxes, built by hand / Dash speakers.. well..
"Chevy craft" paper kickers.
The master cylinder *was* dying. It wasn't normal. So pffft. :-)~
As always, thanks for the advice though.
