Old 03-10-2005, 02:28 AM
Lordipaq Lordipaq is offline
Question Please Help!!! I keep cracking CV joints.
I have a 1989 Honda Accord LXi. I just bought it a week ago. It has a ram air intake, stage 1 racing clutch, performance exhaust, and coilovers. The guy that sold it to me use to abuse this car. He cracked one CV joint. He went and got another CV shaft assembly and replaced it. He drove for about 30 seconds and broke that one. When I purchased the car, I properly installed a new one. While trying to drive up my driveway gently, it broke. It is always breaking the right side axle on the inner CV joint. It blows the roller bearing straight through the wall of the joint. Please help me someone. If you would like to see a picture or would like more information, please email me at [email protected]. Thank you very much.
Old 03-13-2005, 11:43 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Please Help!!! I keep cracking CV joints.
how far is it lowered?
Old 03-15-2005, 07:04 PM
It has been fully lowered before, but the last time the cv joint broke, it was almost raised all the way up. It has broken 3 cv joints so far. I have replaced all the motor mounts in the car. They all were seriously damaged or showed signs or severe wear. I hope this fixes the problem.
Old 03-17-2005, 02:01 AM
just remember a CVjoint is designed to work within a certain range. lower the car you lose range, lose to much, and it will brake through.(as you know) raise the car up to far, and you risk the joint falling out of the socket.
Old 03-20-2005, 10:59 AM
Thanks everybody for your help. The motor mounts were replaced and the car runs again. The mounts that I removed were all completely destroyed. Now that the car is running, I noticed that the gauges don't light up and there is a whining sound only in 5th gear that changes pitch with rpm changes. But, at least its running again.
