Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-10-2005, 12:41 AM
ramon12 ramon12 is offline
sc tuning
i've heard people talk about the max a sc can do, like 930hp.
when I go look at the stats though on a site thats selling it, it'll say 450hp. how do you go about tuning a sc to do the max? they all say its not difficult
Old 03-10-2005, 09:38 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
max hp varies between each supercharger.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-10-2005, 05:41 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: sc tuning
What kind of compressor? Generally you would run a smaller pully to turn the compressor faster. The size of the compressor also matters. But simply turning up the boost isn't just nuts and bolts. Adding more fuel for the added air is actually the most important part of tuning along with adjusting the ignition timing to avoid knock. Upgrading internals will be required at some point.
Instruments needed for tuning should include:
a Wideband O2 sensor
If you are supercharging a vehicle equipped with an OBD system, a scanner will be most helpful to give you timing readouts as timing will vary a lot over the throttle % range.
A dyno equipped shop will have these instruments, or should.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
