How to change interior lighting???
I own a 2003 Blazer extreme that i love, and i recently purchased a new Pioneer stereo for it. The only problem is that it glows blue and my interior lighting is green, and it really clashes. What should i do to get the interior lighting ( dash, gauges, but also windows switch and AC unit) to be blue. Do i need new parts , or should i get different leds color????? Thank you very much as i am clueless on how to do it.
Re: How to change interior lighting???
You won't be able to change it all to blue.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Buy some Nu Image platinum guage, A/C, and Headlight switch covers. They will give you the blue tint you are looking for and look much better than the factory black. I have a picture of them in my 01 extreme, you can check them out at: http://members.cardomain.com/01shavedblaze If you want to see a night view of them, I can get another picture. If you get them, make sure you use some paint thinner to strip the original headlight switch. The original guage and A/C panels peel off, but you the headlight one is painted with clear plastic underneath.
Re: Re: How to change interior lighting???
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Tell us more on why we can't change colors.....do you have special information ?
1999 Blazer LS 4WD 4.3L "W" 2004 Silverado 2500HD Duramax
Re: Re: Re: How to change interior lighting???
I have done something similar in the past. Replaced all idiot, panel and button/knob lights with high output "Laser LED" lamps. You will need to use a current limiting resistor in series with the LED if the LED is not made to run off of 12v. On many of them, bending the leads for the LED through the little twist on cups that hold the bulbs in place is all one needs to do if you stick with 12v LEDs.
There is no secret, voodoo method of making it "work", it will make sense after you start unplugging your panels and stuff.
Actually if you get your normal t1.5 and 194 LED's from www.superbriteleds.com All resistors are included in the bulb sockets... The only resistors I wired in were some 400-600 ohm (depending) for the arm rest controls and dash switches... But none for the clusters.
