Old 03-09-2005, 11:26 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Crank seal
i am replacing most all seals on ZC B4 i put her in. front and rear main seals eazy to replace? do i have to remove oil pump to remove/install rear seal?
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 03-09-2005, 11:40 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Crank seal
rear seal is in the back of the block on the flywheel side, you need to take the flywheel off to get to it
Team Lonely Drivers
Old 03-09-2005, 11:41 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Crank seal
Yes and the front seal you will have to remove the timing belt and crank pulley
Old 03-09-2005, 11:55 PM
Jos4DCivic's Avatar
well i cant get to rear seal cause engine is on stand at the moment. i have everything off (timing belt,water pump,ect...). my question is how do i remove seal? screwdriver?
91 Hatch SI
Finally painted!!!
