Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 03-09-2005, 11:21 PM
TurboLaxx's Avatar
TurboLaxx TurboLaxx is offline
2 ohms or 8 ohms?
I'm about to hookup a single JL Audio 12W6V2 D4 to a Hifonics 600x1 W at 4 ohms. The sub has jumpers on it to connect to 2 (parallel) or 8 (series) ohms. Which one do i connect? Does it really matter? What happens if i dont connect any jumpers?
Old 03-09-2005, 11:59 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: 2 ohms or 8 ohms?
whats the exact amp you're using? Model number?
Empty Pockets Racing Member #1
Old 03-10-2005, 02:03 AM
TurboLaxx's Avatar
i'm running the Hifonics Zeus ZX6000
Old 03-10-2005, 02:08 AM
GScivic7's Avatar
you're going to want to either wire it in parallel and run it off of just 1 channel or wire it in series and bridge the amp and run it that way. Wiring it in parallel and bridging the amp will clip the signal since it's an ohm load the amp can't handle in mono which will lead to destruction of your amp or sub.
Old 03-10-2005, 12:04 PM
TurboLaxx's Avatar
I plan on bridging the 2 channel amp to 1 channel so i guess i'll be running the sub in series. Thanks.
Old 04-20-2005, 09:58 PM
AnotherNewbie AnotherNewbie is offline
You can wire it either way. It depends on what ohm load the amp is stable at... If its stable at 2 ohms Mono, wire it in parallel, if not, series to 8 ohms... Keep in mind, the power of the amp will be substantially lower if you run it at 8 ohms.
Old 04-21-2005, 01:37 PM
millaj92's Avatar
millaj92 millaj92 is offline
Send a message via AIM to millaj92 Send a message via Yahoo to millaj92
Or just exchange it for a 12W6V2-D2 and do it right the first time.
