Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-09-2005, 10:31 PM
Nismo720 Nismo720 is offline
Send a message via AIM to Nismo720
wont start after installing new head gasket
after cleaning up, replacing and reassembling a blown head gasket in a 96 2.0L the car will attempt to start but wont run... you can smell the fuel, we pulled the plugs and checked for spark, theres plenty of spark.
We are not sure though if the MAF is working or not... so we pulled the intake cover and ran the throttle by hand while leaving the MAF wired up still but sitting off to the side... a few times i was able to see a small backfire come out through the intake but the engine would never actually run... any ideas would be very helpful since this is his only means of transportation.
Talcaf
Old 03-09-2005, 10:32 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
is there any wiring harnesses you disconnected during the teardown? Is the cam properly timed?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 03-10-2005, 12:31 AM
cam timing is spot on ...as far as harness connections I went over everything twice and didnt see any loose connections. I'm wondering if the MAF is screwy since when we tore apart the airbox it was full of coolant /gasoline... somehow it had all come back up the air intake setup.
Nismo720
Old 03-10-2005, 09:36 AM
coolant may be on the maf sensor.
"The CEG Nazi"
www.contour.org
Old 03-11-2005, 01:00 PM
frankjc frankjc is offline
Try cleaning the MAF sensor...do not use carburetor cleaner.
Old 04-22-2005, 12:21 AM
Aight still going at this issue... we have since torn the timing down again and retimed it just in case... but it was spot on the first go around... we also replaced the camshaft position sensor... without access to a OBD scanner we dont know if its putting out any codes or not. obviously the car is not driveable and the owner doesnt have the money to tow it anywhere to get it fixed. Any other suggestions on where to look would be greatly appreciated. At this point we are stumped.
Nismo720
Old 04-24-2005, 10:56 PM
im sure this is a given, but new head bolts are being used right?
"The CEG Nazi"
www.contour.org
Old 04-25-2005, 09:47 PM
yes new head bolts and all gaskets new belts as well. one thing that seems to be of concern is that i have not noticed the throttlebody valve open at all when attempting to start the car.
still stumped with the car sitting on stands in the driveway...<grrrrr>
nismo720
Old 04-25-2005, 10:02 PM
perhaps try spraying some starter fluid in the intake while your cranking the car and see if it starts. are you sure your getting fuel?
"The CEG Nazi"
www.contour.org
