Old 03-09-2005, 09:35 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
fuel injector questions
ok, today car wouldnt start and i got a bad injector code, i killed my battery twice trying to start it, killed it once, then brought it home, charged just the battery, then killed it trying to restart it, finally gave up and did the most ghetto thing possible, front bumper of my truck and a buddy in the drivers seat of the car, it took 20 mph to turn it over, and it blew the blackest smoke i have ever seen, in 2 weeks im having the top half reseated at napa, and i know the black was being way rich in the cylenders... the question is, how much would it cost to replace the factory injector(s) on an 89 dx, or would i be better off to do a mpfi? and if i do, what cars can the mpfi come from? any 4 cyl? thanks guys
Old 03-09-2005, 10:10 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
code 16 is almost always the main relay, could you hear the fuel pump engaging when you turned the key to on?
Old 03-09-2005, 11:20 PM
Scott82 Scott82 is offline
Re: fuel injector questions
89 si or hf has Mpfi, as far as having to change anything else like the ECU, Dizzy, ect i don't know, but you'll find some info on the Mpfi swaps if you do a search on this forum that will get you to some links that will help ya out if ya do the swap.
Old 03-10-2005, 09:23 AM
sometimes the fp primes, some times it dont, if it is the main relay, where is it located and how much??
Old 03-10-2005, 09:31 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Re: fuel injector questions
Look at this picture to find the main relay location...
http://www.binghamtonlife.com/manual...es/91-23-6.jpg
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 03-10-2005, 12:49 PM
not working
Old 03-10-2005, 01:33 PM
The site with the manual has been disabled and I just deleted the other bookmark web site with all pdf pages of it. Sorry. Just search main relay here and you'll find it. I'll try to describe where it's located though. It's adjacent to the change tray sort of next to where the plastic of the dash meets the door panel. If you remove the change tray and bend your head to look up over the hood release (that relay right there is the starter relay so leave it be) it'll be sideways flush with the side of the chassis.
2010 Honda CR-V EX
Old 03-10-2005, 01:46 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
its a bitch to get to. best bet (if your big) take all the shit off on the drivers side.(the peace with the vent that go's into the door and all them panels there. you will see a 10mm (i think) bult just next to the hood latch(thak that off to) the brackit that is held on by the bult will have the relay at the top of it. it is about 3" wide and 1.5" thick or so...it dosnt come out to easy. i didnt even put mine back there i moved it to a spot i found under the dash.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 03-10-2005, 02:11 PM
ok, thanks guys
