Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-09-2005, 07:39 PM
sunfire_ca sunfire_ca is offline
Odometer Problem - Lights out
My odometer is no longer lit and I want to investigate why. It went off one day and then came back on the next day. It is now off. Is there a recall?
Old 03-23-2005, 08:48 AM
tvnvideoman tvnvideoman is offline
Send a message via AIM to tvnvideoman Send a message via Yahoo to tvnvideoman
Re: Odometer Problem - Lights out
Not sure about a recall, but mine had to be sent to a special place to get the bulb replaced. (The dealership did it under warrenty, so I don't have the details, but somehow the bulb went out.) Ask your local dealer for info on someone to fix it. Not sure what year, but after 2000 (maybe) the complete thing is SEALED, and cannot be opened... or something like that. good luck
Old 03-30-2005, 09:08 PM
Thanks for the reply. It is a 2002 sunfire. I'm currently working with the GM dealer to resolve this issue.
Old 04-08-2005, 01:11 AM
canfire canfire is offline
Sunfire_ca did you find out what the problem was? I am interested as I am having the same problem with my 2002
Old 02-16-2010, 01:44 PM
sunfire64 sunfire64 is offline
There is a cheapie light bulb that illuminates the display it is very hard not to impossible to replace i ve done mine, the problem is that you have to remove the needles from the cluster without breaking them then separate the board from the rest (eveything is clipped together) now unclip the white plastic cover for nthe odometer (it dos not come off so just bend the wiring with the odmeter display carefully) un solder the cheapie light bulb. i replaced it with one from circuit city ($5)
note if the needles came off with the shafts you are going to have to remove the white cover remove the gear and fit the shaft back in the gear. make sure that the gear is not binding in the gear cover (be carefull to not loose the black gear inside)
to calibrate the f-cking thing: fill up tank first warn up th engine
at this point don not push the needles right down yet in order to calibrate
start the engine place the rpm one around 900 rpm the spedometer one to 0
the fuel to full and the temp one to 190 or 90 celsius
check that it is ok then push the needles fully
Hope this helps!
