Old 03-09-2005, 03:54 PM
crazyhorse1964 crazyhorse1964 is offline
1999 Ford Escort ZX2 Won't start
Hello,
My problem started with a bad alternator (lights dimmed then died)
I charged up battery and removed negitive cable and car stalled.
I replaced the alternator but didn't get the serpentine belt back on correctly and it shredded off. I replaced it and now it won't start. I checked all wiring that the shredded belt may have come in contact with and I don't see any damage.
I have checked for spark and I'm getting good spark.
Any suggestion what I can check next..
Thanks Steve
Old 03-09-2005, 03:58 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
Re: 1999 Ford Escort ZX2 Won't start
starter
Old 03-09-2005, 04:01 PM
Re: Re: 1999 Ford Escort ZX2 Won't start
Originally Posted by TheStang00
starter
The car cranks fine..Do you still think its the starter??
Old 03-09-2005, 06:31 PM
TheStang00's Avatar
no not if it cranks. not sure what to tell u then... is the battery charged?
Old 03-09-2005, 07:06 PM
Are you for real? you have no idea what you are talking about..
Please save the replys for someone that knows something about this..
Old 03-10-2005, 05:54 PM
roblemmon roblemmon is offline
Lightbulb ideas
Did you check if its getting fuel and make sure the timing belt didn't snap also.
Old 03-10-2005, 08:18 PM
Re: ideas
Hi, I checked the timing belt and its OK, its getting spark, but I'm not sure about the fuel. I don't know a good way to check to see if its getting fuel. Any Ideas??
Old 03-11-2005, 05:31 AM
Lightbulb fuel
see if injectors spray
Old 03-11-2005, 03:12 PM
Davescort97 Davescort97 is offline
Escort guy
It will turn over but not start. Check your crankshaft pulley and harmonic balancer. They have a tendancy to separate. On my 97 I had the same problem. I also had the same thing happen on my 1995 wagon. This could be why your first belt shredded. While your in there, check the key on the crankshaft and pulley. It could be out of time for that.
An easy way to see if it is not getting fuel can be had by spraying some starter fluid in the intake and seering if it will run for just a second or
two. If it runs you are not getting fuel. If it doesn't run you you know it isn't getting spark at the right time. All the best!
Old 03-11-2005, 09:31 PM
new idea
The camshaft position sensor could be unplugged or bad,and the fuel timing could be off
Old 03-12-2005, 07:44 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Re: ideas
get some gumout throttle body spray and spray it down the throat of the throttle body if it runs for a second after that then you have a fuel delivery problem. Let us know
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
