Old 03-09-2005, 03:06 PM
pirates4ever pirates4ever is offline
95 4.3l W having serious issues, need help
Hey guys,
I got some great advice last time I posted regarding my EGR valve so I'm hoping to have the same results.
This morning when I cranked my truck the idle was incredibly rough. I immediately suspected the EGR. I went to get some gas and had almost NO power and a lot of "puttering" out of the tail pipe. So I come home, take off the EGR valve and clean it. It wasn't dirty. Get everything back together and I'm having the same result.
Symptoms are:
LOTS of white smoke coming out the back with a VERY heavy smell of fuel. A short test ride resulted in me using about a 1/4 tank of gas.
I checked my Throttle body and found it moist inside.
I'm not mechanically savy so any help will be appreciated. I have a feeling this is a bad one.
Old 03-09-2005, 08:47 PM
OverBoardProject OverBoardProject is offline
Banned
Re: 95 4.3l W having serious issues, need help
check the PVC valve. It's a little 1 way valve that goes on the valve cover, with a hose going up to the air filter assembly.
If you can hear a ball shacing around in there it's probably good. But still blow on it from both sides, it should seal one way but not the other
Old 03-09-2005, 09:24 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
white smoke= watervapor ie coolent
Old 03-10-2005, 07:17 AM
Well, I checked the PVC valve and it appears to be fine.
On a hunch of a blown head gasket, I also checked my radiator fluid levels. That also appeared to be fine.
I'm going to try to run the truck for a couple of mintues tonight to see if any other symptoms jump out. I did notice a damp spot under the exhaust on the ground that appeared to smell like fuel. But that could have been the fact that I had just generated 40,000 cubic ft of smoke that also smelled like fuel.
Any other ideas?
Old 03-10-2005, 07:36 AM
blazee's Avatar
blazee blazee is offline
Problem?
Does the oil smell like gas? If it does you shouldn't drive it.
Sounds like it could be a leaking CPI.
Old 03-10-2005, 08:19 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Yeah, with the gas smell, you could be dumping fuel... Drop about a cup of oil and see if it smells like gas..
Old 03-10-2005, 09:11 AM
I'll be sure to check those things guys. Appreciate the lead.
What would I be looking at as far as repair costs...hypothetically?
