Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-09-2005, 03:43 PM
clariveros's Avatar
clariveros clariveros is offline
ABS Brakes?
Hello,
I am think my speed sensor is going bye-bye, on my jimmy, now this only happens on cold mornings 25ºF (-3ºC) or less, it has happened about 3 times on 3 different days. What is happenig is that i can be comming of the highway and braking slowly and it is fine but when I really press the brakes to stop on the line the abs comes on and i have to press hard the peddle to stop. today it did it when i was comming out of a gas station at less than 15 mph.
Now when this happens it does not pull to any side and it is on dry surfaces, it only does it once and not anymore, on a different ocassion i have tried slamming on the brake to activate the abs but it seem to be working fine at other times, so what can my problem be???
I really hope that it is a cheap fix cuz i really dont want to spend another $350 on a wheel hub just to get a new sensor
2001 GMC Jimmy SLS 2-door Manual Trans 2wd
120K miles and still going - (Not Anymore, ABS screwed me and at 70 mph locked the front wheels and caused me to roll it and it sits in my garage now ) members.cardomain.com/vemucla
2007 Ford F150 supercab lariat 2wd
Old 03-15-2005, 11:35 PM
94 Jimmy 94 Jimmy is offline
I've had this problem twice on two different cars. On my son's 94 Jimmy after he installed a lift kit, the brake line and wheel speed sensor wire rubbed on the wheel and wore thru the wire to the speed sensor. Fixed the wire and all was OK.
See ya, let us know what you find.
94
Old 03-16-2005, 09:27 AM
clariveros's Avatar
Re: ABS Brakes?
well nothing has happend since that day, i made the post, i am goint to lift the car this weekend to see if there is anything visually wrong, will let you all know how it goes
Old 03-17-2005, 05:46 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: ABS Brakes?
remove and clean your front hub speed sensors.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-17-2005, 05:59 PM
clariveros's Avatar
Re: ABS Brakes?
what kind of grease doe sit use for this, i know that it is a blue colored one, and for cleaning them should i just wipe them with a clean cloth? thanks for your help LT and 94
Old 03-17-2005, 06:33 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: ABS Brakes?
Wheel bearing grease.
Cleaning might require a little TB cleaner or something to get the crud off.
Old 03-19-2005, 11:19 PM
clariveros's Avatar
Re: ABS Brakes?
well i cleaned the abs sensors in the front for both front wheels so hopefully it wont happen again, wish me luck, thank to all.
Old 03-19-2005, 11:25 PM
BlazerLT's Avatar
AF -Advisor
Re: ABS Brakes?
Glad to have helped you bro!
Old 03-20-2005, 09:55 PM
clariveros's Avatar
Re: ABS Brakes?
hey, thank you LT, hey and sorry if It seemed like i snapped at you the other day,
Old 03-20-2005, 11:13 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: ABS Brakes?
Hey, no harm, no foul.
All is well.
