Go Back   Automotive Forums Car Chat > Mitsubishi > Mighty Max
Old 03-09-2005, 02:33 PM
monstermatic monstermatic is offline
Send a message via MSN to monstermatic
balance shaft ?'s
Hi, tried to search for this but didn't find anything. I have an '89 Ram 50 with the Mitsubishi 2.6 four cylinder. I'm curious about the balance shaft elimination kit available for this engine. Have any of you used this? If you have, does it cause a lot of vibrations or roughness? My balance shaft bearing went and beat the shaft up a little. So I'm thinking about going this route. Anything anybody can tell would help a lot. Thanks.
Old 06-18-2005, 07:11 PM
thecourtd50 thecourtd50 is offline
balance shaft
if youre still pondering the balance shaft elimination kit, do it get rid of the shaft its worthless. i installed the kit on my truck after about 120000 miles and wished i had done it sooner. just my 2 pennies
dpr..........dirt poor racing
Old 06-19-2005, 01:30 PM
Actually I put it all back together and haven't had any problems. Thanks for the reply tho, if the bearing ever goes again i'll just do the elimination.
Old 09-03-2005, 09:45 AM
mechgt mechgt is offline
How do I replace the balance belt?
I was replacing the water pump in my 89' Mitsubishi (2.0L) and found that the balance belt was busted. I got a new belt but can't seem to figure out how to get it on. There's not enough clearance around the crankshaft gear to get the belt on at the bottom.
Old 10-01-2005, 10:33 AM
Rich's Avatar
Rich Rich is offline
Never Fear, Rich is here!
Send a message via MSN to Rich
Re: How do I replace the balance belt?
You have to actually remove the crank timing pullies and slide the pully back on with the belt.
Once you remove the crank bolt, you should be able to remove the timing pulleys fairly easily.
Hope that made some sense.
My Wheels
15' Kia Soul SX 2.0L
13' GMC 1500 P/U 5.3L
