Interesting info on ecm for 95/96/97 ECM's
Well, as the time draws near for my 5.7 vortec swap, I'm accumulating more and more information...My biggest concern has been the ecm and electrical system for the motor. So I've been haunting my local dealerships for various manuals to copy and printouts from their TTII system.... I found out some very interesting things...
95's with ODBII (ecm under the hood) ECM's/harness' have the EXACT same pin outs, circuit id's and colors as the 96/97 ECM's/harness'. The only real variance is on that harness for the injector connector (obvious) and the MAF vs MAP sensor...(and a couple of other accessory connectors) But even with those connectors, the same voltages, resistance values, circuit id's and colors are EXACTLY the same... This includes the pin outs at the firewall. I decided to go a little bit farther and grab a couple of ecms, 1 from a 95 and 1 from a 97... After tearing them apart all chips, circuit boards etc are EXACTLY the same... Which means that all the tech 2 system is doing is wiping the eprom and inserting different values for the pulsing systems for the injectors and a few other things... What does this mean? It means you could easily take a 96-current vortec motor with a 96/97 ECM and harness and drop it straight into your 95. (Obviously you would need the proper accessories for the motor, I.E. Ac pump, alt, sensors, etc) I've looked at the schematics of the harness's and as I said, the circuit id's, colors, and resistance variables are all the same...heh...I wish I knew this when my original motor blew! I should also note that the k1500 harness is basically the same as the others except for additional wires for the 5.7 injector system.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Re: Interesting info on ecm for 95/96/97 ECM's
Excellent info Rlith.
I am awaiting your swap with baited breath.
1995 Factory Blazer Service Manual for sale, PM if interested. |
What ecm are you using for the swap? I heard you were using a 5.7 from an escalade- are you using its ecm and harness, or your factory?
The engine is from a 99 escalade. I'm using a k1500 ECM and harness... Virtually the same thing as the 95-97 harness with the diff being some pigtails and the injector connector... Also using a conversion oil pan (to clear the cross member) conversion 2.2 mounts, ls1 conversion headers, the ecm will be reprogrammed on it's fuel curve, and a more agressive cam has been added.
Please Pleas Please photograph and document this from start to finish.
Re: Re: Interesting info on ecm for 95/96/97 ECM's
2003 Honda Element EX 2002 Kia Spectra (can't "Improve" or wife will kill me) 1986 Dodge Ramcharger (For sale with a 1966 Rambler 660 classic to boot) ![]() " Idon't know how many of them it would've taken to whoop my ass, but I knew how many they were gonna use. Thats a handy little piece of information to have right there." "Ron White" http://www.myspace.com/officer_redneck |
Re: Re: Re: Interesting info on ecm for 95/96/97 ECM's
Actually I wanted to do an LT1 or LS1 but that is such a wiring nightmare... I just wanted to keep it simple... A buddy of mine did an LT1 in an s10 pickup and converted to AWD... I've driven that truck and it hauls ass...The amount of wiring he had to do was insane...The S10 Wildside.... ![]() ![]() ![]()
