Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 03-09-2005, 02:01 PM
1999montana's Avatar
1999montana 1999montana is offline
Power Sliding Door (PSD) Re-Initialization Procedure
Here is the procedure for re-initializing the power sliding door. Usually, the problem manifests itself during an aborted open or close, which throws the logic control module off. I have used this procedure myself several times to fix a ‘dead’ door. It should work on the Venture and Silhouette as well, although I cannot guarantee.
The reference to the Diagnostic Modes permits the technician to discover what caused the door to stop working and identify any failed parts (motor, sensors, module etc). I DO NOT have the diagnostic code information.
** USE AT YOUR OWN RISK **
This is quoted verbatim from the GM service bulletin...
" IMPORTANT:
Before you perform the PSD re-initialization, check for Diagnostic Trouble Codes (DTCs) by performing Diagnostic Mode 1. Refer to Diagnostic Modes for the procedure.
Perform the following PSD re-initialization procedure when ANY of the following conditions occur:
· The PSD is inoperative
· Reconnecting the vehicle battery after being disconnected
· After recharging vehicle battery due to a low or discharged battery condition
· After reinstalling or replacing the radio fuse located in the under hood accessory wiring junction block
· Exiting any of the diagnostic modes. Refer to Diagnostic Information Procedures
Perform this procedure in order to re-initialize the PSD:
1. Set the PSD on/off switch in the overhead console to the OFF position
2. Manually open the PSD completely
3. Manually close and latch the PSD
4. Remove the radio fuse
5. Wait 30 seconds
6. Reinstall the radio fuse
7. Wait 10 seconds
8. Set the PSD on/off switch in the overhead console to the ON position
9. Press, then release either PSD open/close switch (on the overhead console or the one on the 'B' pillar) in order to completely open the PSD
10. Wait 5 seconds
11. Press, then release either PSD open/close switch (on the overhead console or the one on the 'B' pillar) to allow the PSD to close completely
12. Wait 5 seconds
13. Repeat steps 8 through 11 and re-check for proper PSD operation "
