Old 03-09-2005, 12:53 PM
Verminator's Avatar
Verminator Verminator is offline
Send a message via AIM to Verminator
Shelf life of brake fluid (dot 3 )
Does brake fluid have a fixed shelf life with regard to getting off paint, I I have had a batch for around 6 months, stripped about six models but it seems to be struggling lately to do its job. I'm not using any different paints than i would normally, any ideas?
Old 03-09-2005, 01:06 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Yes, it does get weaker over time, especially as it is exposed to the air. I keep mine in an air-tight plastic container and it still worked acceptably well after about 3 years.
Old 03-09-2005, 01:46 PM
jswillmon's Avatar
jswillmon jswillmon is offline
Send a message via AIM to jswillmon
Re: Shelf life of brake fluid (dot 3 )
I periodically strain the muck out of mine and clean the bottom of the container b/c after a while i have a thick buildup of mush in the bottom. I seems to be less effective after it gets really dirty. I've had mine in a big tupperware bowl for over a year and is still running strong.
The Name's Jesse!
**Click the pic for my latest build, Daytona Blue 350z**
Old 03-09-2005, 04:35 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
Re: Re: Shelf life of brake fluid (dot 3 )
Yea, same here. After a few months and a few cars stripped my Brake Fluid lost its strength. I would keep it in an air tight container, like SteveK2003 said, for next time.
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
Old 03-09-2005, 07:50 PM
freakray freakray is offline
AF Modelrater
The other factor to consider is moisture, brake fluid tends to draw moisture so if it's not in a completely sealed container it will also make it weaker/less effective over time.
AF User Guidelines
Old 03-10-2005, 06:18 AM
Verminator's Avatar
Mine has been in an unsealed container so I can assume thats my problem, as brakefluid is a product of refining as is petrol etc then I can only think that the chemicals that do the stripping must evaporate off if left open to the air. Will put my next lot in a tub with a lid. Thanks for the info guys.
