Old 03-09-2005, 01:26 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Electric fan?
Does anyone have any recommendations for a good electric fan? Dual or single? I'm not sure how much of a fan I need for my combo in my sig.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 03-09-2005, 01:27 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Electric fan?
Mark VII fan will blow your doors off.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 03-09-2005, 01:52 PM
Re: Re: Electric fan?
Just wanna make sure Mark 7, or 8? How much might one be used or would I be better off getting a new replacement? Thanks Skyline.
Old 03-09-2005, 02:41 PM
SkylineUSA's Avatar
Re: Electric fan?
I got a Mark VII from ebay for $90 last year, it will move some air. I believe the earlier mods move more air because of the fan blade pitch, but they are a lot louder under the hood.
Old 03-10-2005, 01:27 PM
How well does it fit? Any modifications that need to be done? How would I know how to wire it up?
Old 03-10-2005, 01:34 PM
What about a Mark VIII fan? There are 2 on ebay now. One of them says it can pull up to 4000cfm.
Old 03-10-2005, 02:52 PM
SkylineUSA's Avatar
Re: Electric fan?
That is a good one. That can support any thing you can throw at it, just make sure you run a shroud.
Old 03-10-2005, 06:04 PM
Re: Electric fan?
Eh?
Old 03-11-2005, 01:34 AM
SkylineUSA's Avatar
Re: Electric fan?
Google it, there use to be an awesome site that had a complete write up of an install.
Let me know if you cannot find it.
Old 03-11-2005, 12:15 PM
importeater5_0 importeater5_0 is offline
Send a message via AIM to importeater5_0
Re: Electric fan?
damn, u got that fan for 90 bucks, i paid 220 for a flex-a-lite single fan, and i hear that the flex-a-lites arent even that great.
Old 03-11-2005, 01:13 PM
SkylineUSA's Avatar
You have to know whats good, and whats not. Just ask the guys before you spend your cash.
But with the $220, that came with everything right? Thermo switch, relays, wire, etc.
I had to buy all that extra stuff, but then again, my car will over heat with that flex single fan.
Old 03-12-2005, 01:19 AM
Re: Electric fan?
yea it came with everything, the summer hasnt come yet im hopin my car wont overheat.
Old 03-17-2005, 01:48 PM
YES! I got myself a fan. For $91 I got a low mileage Mark 8 fan in good shape and very clean, off e-bay. Should be here next week. So what kind of other stuff like relays, etc, will I need?
Old 03-28-2005, 01:39 PM
Ok, so now I have a problem. It doesnt fit! In fact I probably need another inch to clear the water pump. I thought these were supposed to fit fairly well. Any ideas?
Old 03-28-2005, 02:04 PM
SkylineUSA's Avatar
Re: Electric fan?
Can you cut the shroud and make it fit? A lot of guys use them, so there should be a way to modify it. so it will work.
I am running two 30 amp relays in parallel for the current draw. One 30amp will not hold the load.
