Go Back   Automotive Forums Car Chat > Ford > Mustang > Specialty 'Stangs
Specialty 'Stangs Are you a Saleen, Shelby, or Rousch enthusiast? If so, this is your forum.
Old 03-09-2005, 12:14 PM
SMOKEY818 SMOKEY818 is offline
2004 mustang saleen hp ?
damn yesterday i saw this 2004 mustang saleen, it had badges saying it had a supercharged 281 how much hp does it pushed, this stang looked pretty sweet
89 Camaro with lt1/t56/headers,borla exhaust,ac delete, march pulleys, slp CAI,3.73 gears,msd ignition,port & polished heads, reprogrammed pc, free mods, hotchkis suspension,sub-frame conn & weight reduction.
Old 03-09-2005, 12:35 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: 2004 mustang saleen hp ?
Like this?
Engine
- 4.6L Saleen Centrifugal Supercharged OHV 90 degree V-8
- Horsepower - 505 @ 5400 / Torque - 500 ft. lbs. @ 3500
- Compression ratio 8.2:1 / Bore and stroke - 4.00" x 3.50"
- Sequential electronic fuel-injection
- 65 mm throttle body
- Saleen upper/lower manifold
- 80 mm mass-air sensor
- 36 lb./hr. fuel injectors
- Hydraulic roller camshaft and lifters
- Forged aluminum pistons, aluminum heads
- Saleen ceramic coated headers
- Saleen 2.5" stainless steel 4-way catalytic high flow exhaust
- High flow fuel pump
- Premium fuel calibration
- Saleen high performance radiator
Drivetrain
- Saleen Quick Ratio 6-speed manual transmission
- Ford 9" Limited Slip differential
- Custom balanced driveshaft
Suspension
- Front: Saleen independent uneven length double wishbone with Saleen N2 triple adjustable shocks and adjustable sway bars
- Rear: Saleen 3 link live axle with sway bar
- Performance Enhancements: Unibody construction with roll cage and suspension reinforcement, power assisted rack and pinion steering
Brakes
- Power 4-wheel ABS disc brakes with integrated cooling ducts
- Front: Saleen 14.4" metallic disc with 4-piston calipers
- Rear: Saleen 13.0" metallic disc with 4-piston calipers
Wheels
- Saleen five spoke alloy wheels
- Front 18" x 10"
- Rear 18" x 11"
Tires
- High performance Pirelli PZero,
- Front: P285/30 ZR-18
- Rear: P335/30 ZR-18
________________________________
Performance Numbers
- 1/4 Mile - 11.8/124mph
- 0-60mph - 4.0 seconds
- Lat. Accel. - 1.09 g
- Braking 60-0mph - 98 ft
Google is your friend
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 03-09-2005, 01:00 PM
yeah that was it, damn its pushing out 505hp
Old 03-13-2005, 09:05 AM
IS THAT A HEMI???'s Avatar
IS THAT A HEMI??? IS THAT A HEMI??? is offline
that is one bad ass stang. wounder if they made one for 05
Old 03-13-2005, 07:10 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
they did
Old 04-04-2005, 08:33 PM
Muscletang's Avatar
Muscletang Muscletang is offline
AF Premium User
It's a nice Mustang and has some ungodly numbers but for $150,000?
For a long time it gave me nightmares... witnessing an injustice like that... it's a constant reminder of just how unfair this world can be... I can still hear them taunting him.......
silly rabbit, tricks are for kids...
I mean, WHY COULDN'T THEY JUST GIVE HIM SOME CEREAL?
Originally Posted by Lars Ulrich
What?! Record sales are slumping? Must be from all those pirates. Can't be because we started sucking 10 years ago.
Old 04-06-2005, 09:26 PM
Ghost96Gt Ghost96Gt is offline
Send a message via MSN to Ghost96Gt
yeah dude isnt that the E model i thought the 281 sc was in the 400 range? for 50 grand? and has the dual exhaust on th outer edges of the rear bumper more like a normal gt. also the 281 sc i am pretty sure is running a 5 speed and runs a roots style blower with 8 or 9 lbs of boost. might be wrong though.
Old 04-06-2005, 09:27 PM
also forgot to say the E model is in the high 60's or low 70's thousand.
Old 04-26-2005, 10:14 PM
mustangcynth mustangcynth is offline
Unhappy Can't figure out if it's a real Saleen, help!
I'm new to the Saleen world. I have found a 2004 Saleen (so it says) at a dealership but I'm skeptical. It says it's only got 290hp. I thought the Saleens were at least 445 starting? Can someone please advise?
The dealership isn't even advertising it as a Saleen, yet I saw the car tonight and it has Saleen written all over it, literally. I am starting to wonder if the specs for this car are wrong. But it visibly looked exactly like a 2004 S281 (E or SC I don't know?).
Here's the specs from online:
2004 Ford Mustang GT Deluxe
2 door Coupe, RWD, 4.6Liter
Specifications & Dimensions
Wheelbase 101.3 inches
Overall Length 183.2 inches
Vehicle Height 53.1 inches
Vehicle Width 73.1 inches
Front Headroom 38.1 inches
Front Legroom 42.6 inches
Rear Headroom 35.8 inches
Rear Legroom 29.9 inches
Curb Weight 3347 lbs
Seating Capacity 4/4 passengers
Final Assembly Location United States
Brakes
Antilock Brakes Optional
Ventilated front disc / solid rear disc Standard
Drive
5-speed manual transmission Standard
Engine
4.6L V8 260 hp gas Standard
Number of cylinders: 8
Number of valves: 16
Camshaft: Single overhead cam (SOHC)
Horsepower: 260 hp @ 5250 rpm
Torque: 302 ft-lbs @ 4000 rpm
Fuel Capacity (gallons): 15.7
Fuel Economy (City/Hwy): 18/23
Suspension
Front independent suspension Standard
Front and rear stabilizer bar Standard
Wheels
17 x 8.0 in. Standard
Tires, P245/45ZR17 Standard
Tire type, performance Standard
Steel Standard
Old 02-17-2006, 02:48 PM
6speed's Avatar
6speed 6speed is offline
the 505hp model talked about above must be the S351R. no saleen came with a centrifugal blower besides that one. they stopped making it in 99 when they started developing the E model.
for 2004 the S281 has 290hp (chip, pullies, k&n, borla, suspension, shifter)
S281-SC (whipple series IV twin screw 360hp)
S281-E (whipple series V twin screw 440hp)
no saleen came with 18x10s F and 18x11s R either
the car above me here those details are for a GT (ie 260hp, 17" wheels) if the dealor has a saleen and you are unsure, call up saleen with the VIN number theyll give you the details on it. and N/A saleens came with 290hp like mine from the factory.
07 jeep cherokee srt8
99 saleen s281
05 cbr 1000rr
Old 04-21-2015, 03:20 PM
mustang nalley mustang nalley is offline
I have a 2003 Saleen s281-e it has a 5 speed transmission. With a 4.6 super charged v8 it dynode at 420hp at the wheels. The tech said that it was around 500 to the motor. So ya those speaks are right.
