Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-09-2005, 10:48 AM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
Angry 95 Gsx
I got a problem with my car. Im diving along with the gas pedal stepped half way then I let go and it stays pressed for a while. when Im shiftin gears it seems like I leave the gas pedal pressed because say im going to 3gear and it revs up itself. When Im just parked and rev up the rpm's then let go it keeps on going for like 3/4 seconds. And when I am reving it up in the engine it does not do nothing it gos back down right away. So Im guessing its the pedal but anybody got any ideas how I could fix that.
Old 03-09-2005, 12:20 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: 95 Gsx
Sounds like a sticking throttle cable.
Does it do it if you rev the car up manually under the hood?
Kris
2012 Genesis Coupe 2.0t
Old 03-09-2005, 12:37 PM
Re: Re: 95 Gsx
Nope it doesnt do that when I am doing manually
Old 03-09-2005, 08:26 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 95 Gsx
I've seen really shitty throttle plates/throttlebodies hang up like this as well.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-10-2005, 11:54 AM
Re: Re: 95 Gsx
So could it still be the throttle cable???
Old 03-11-2005, 08:17 AM
AF - Advisor
Re: 95 Gsx
It could be both. Its not a contest to see who can come up with the best answer. There can be many possible causes for one set of symptoms. Its our job to list as many as we know and think to be likely, your job to go out and try them all
Looking at post number 3 Lando is probably on to something. I would do that first, its only ~30 bucks for the non-cruise cable, not sure how much it is when you have cruise. Also, With cruise it could be one of the two cables used, or the junction box, so if you ever thought of getting rid of the cruise control now is the time.
Kevin Jewer
Old 03-18-2005, 10:27 AM
Re: Re: 95 Gsx
Originally Posted by 95 GSXracer
It could be both. Its a contest to see who can come up with the best answer. There can be many possible causes for one set of symptoms. Its our job to list as many as we know and think to be likely, your job to go out and try them all
I got it fixed thanks guys
Old 03-18-2005, 10:42 AM
AF - Advisor
Re: 95 Gsx
Thanks for the useless info. Post what the fix was so people that may find this thread in a search might get some useful info, and we wont have to have the best answer contest again.
Kevin Jewer
Old 03-18-2005, 12:47 PM
Re: Re: Re: 95 Gsx
Sorry guys. What I did was just spray wd-40 where the throttle was, lots of it so it wouldnt get stuck thanks guy for ur help.
