Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-09-2005, 10:08 AM
Burton Boys Burton Boys is offline
1994 jimmy dash lights
How do you get to the dash lights? The one on the right is still working, the one on the left behind speed ommiter is out.
Thanks in advance for any advise.
Old 03-09-2005, 01:30 PM
johnpsu johnpsu is offline
Re: 1994 jimmy dash lights
The ones illuminating the dash cluster?
You have to rip apart the dash, & remove the cluster from the
dash.To get at it you have to take out the heating, a/c, defrost
and 4x4 controls, light switch controls, etc.
Basically, all you need to tak out the control switches
are flathead and phillips screwdrivers, before unpluging and
uncliping the connections.. Then you will
need a deep socket 10mm to get at the nuts holding
down the plastic thing surrounding the cluster, & the cluster itself.
While doing this dont forget there is a gear indicator cable
than runs from the bottem of the cluster and clips on to the
steering collum.
YOur going to have to remove a handfull of little pannels below
the cluster and steering wheelto get at it... If your going to remove
it completely
Mounted on a blue knob, there are quarter turn,
screw in bulbs in the back. They might be a dealer item?
Old 03-09-2005, 01:55 PM
Re: Re: 1994 jimmy dash lights
steering collum.
it completely
Thank you so much. I had no idea where to start.
Old 03-13-2005, 02:45 PM
84fiero123's Avatar
84fiero123 84fiero123 is offline
take the lower garnish panels and heater duct out, you may be able to get your hand up behind the dash that way and just turn the bulb socket conterclockwise 1/4 turn pull bulb and socket out. bring unit to napa they will have a replacement peanut bulb.
technology is great when it works
but one big pain in the ass when it doesn't
Detroit Iron Rules, all the rest are just toys!
Old 03-13-2005, 06:09 PM
Thanks. That sounds easier than the other.
Old 03-14-2005, 06:50 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: Re: 1994 jimmy dash lights
Pull the cluster, much easier then trying to get your hand up there... Also take a look at this thread regarding replacement bulbs with clusters. This will for the most part apply to yours as well.
Old 03-14-2005, 07:10 AM
Re: Re: Re: Re: 1994 jimmy dash lights
Ok. Thanks.
Old 03-15-2005, 06:03 PM
Hmm i dont see how you could get your hand behind there without unbolting it or taking almost everything out. It cluster is bolted against another panel where
the electical connectors are located.
Old 03-15-2005, 06:09 PM
Have you done this before? (I'm just a "dumb" girl not sure where to start.) Also, have you changed out the window motors? Saw several on ebay. I've got to get this truck ready by May for my son. Thanks.
Old 03-15-2005, 07:01 PM
rlith's Avatar
For a good how-to on the window motors, look here http://www.usedpartscentral.com/tech/page1.htm
Old 03-16-2005, 08:23 AM
Thank you.
