Old 03-09-2005, 09:57 AM
marine90 marine90 is offline
Transmission flush vs fluid and filter change
I have been reading that many people have had problems with transmission flushes. Shortly after being performed people started having trans. problems.
1. Is there any truth to that statement?
2. Would it be just as good to just do a fluid and filter change instead?
3. Doing the f/f change myself would I need to replace the pan gasket or reuse the old?
Old 03-09-2005, 10:05 AM
BIG-L's Avatar
BIG-L BIG-L is offline
It is re-useable...Try doing a search,since it has been talked about before in the past,in a heated discussion Just call me old fashion,I prefere the standard F/F change
~Larry~
ClubGP Member 6530
Since 2001
Old 03-09-2005, 10:07 AM
Yeah I think I will just stick with the f/f.
Thanks Larry.
Steve
Old 03-09-2005, 10:14 AM
BIG-L's Avatar
Here are some instruction's on changing the filter Click Here
~Larry~
ClubGP Member 6530
Since 2001
Old 03-09-2005, 05:27 PM
jon95se jon95se is offline
Re: Transmission flush vs fluid and filter change
hehehe no comment
Old 03-09-2005, 08:31 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Yeh a flush on a vehicle with moderate to higher message can break loose bad crap that's built up in the tranny. This stuff can get into things and cause problems, such as a slipping tranny. I'm deffinately with the f / f
Old 03-09-2005, 09:43 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Transmission flush vs fluid and filter change
I agree with the others. No flush. You should have a preformed rubber tranny oil pan gasket...definitely reuseable. I'd recommend sticking with the AC Delco filter only. Part number: TF304 - 25313825 for GP or Regal with 4T65-E and 4T65E-HD tranny. Same for 4T60-E. Cost approx. $22.00. Plus you'll need 7 to 8 quarts of good quality Dextron-III such as Castrol to re-plenish.
Old 03-10-2005, 11:14 PM
v8soldier v8soldier is offline
Send a message via AIM to v8soldier
Yeah I think I remember the old thread too but Ima put in my two cents. I'm a big fan of the tranny flush with a filter and pan gasket change combined. However, if you have anything more than 75k on the tranny and have never had it flushed before I would stick with the fluid and filter change. The full tranny flush pretty much has to be done on a regular schedule to keep the horror stories from happening to you.
