Greetings to all. I have a question. On an older post, I had explained the drama about the upper t-stat housing bolt breaking, not once, but twice. Well, the bolt is out, finally, threads are in surprisingly enough great shape, just the usual crud and goo. So, I call my local dealership to get the upper bolt because my local autoparts place said they did not have it. I found out that the upper bolt is discontinued, the lower bolt is still available, but the upper is not.....figures. Would anyone happen to know the specifics on the bolt? Length, thread, size etc? Any help would be appreciated. Thanks in advance.
OK IM dum. What a t-stat? Tranny or transfer case or what. Whatever it is I would try and figure out why the bolt keep breaking. Fix that before something else breaks off a lot more costly than a bolt. LUCK
Re: Puzzled on Bolt
Sorry about that. It is the upper bolt for the thermostat housing. My thermostat had failed so I was replacing it when the head of the top bolt broke off. Then, it broke again at the block.
Re: Re: Puzzled on Bolt
[email protected]
Re: Puzzled on Bolt
the upper bolt should be part #6034356 and its still available its $2.35.the specs are 5/16-18x2.38
