Old 03-08-2005, 11:47 PM
CATMECH CATMECH is offline
1999 S10 2.2 Wont Crank
I Have A 1999 S10 2.2 LITER. I PARKED THE TRUCK FOR 5 MINUTES. NOW IT WONT CRANK. IT JUST CLICKS AT STARTER. ALL LIGHTS DIM. BATTERY VOLTAGE AT BATTEY 12 VOLTS. DASH SHOWS 9 VOLTS. BATTERY CABLES GOOD, AND NO BLOWN FUSES. ARE THERE ANY OTHER CIRCUIT BREAKERS, RELAYS, OR FUSIBLE LINKS OTHER THAN THE TWO FUSE PANELS. THE VOLTAGE SEEMS TO COME AND GO WHILE SITTING IN THE TRUCK. DOME LIGHT WILL BRIGHTEN AND DIM BY ITSELF, AND VOLTMETER WILL GO FROM 9 VOLTS TO 12 VOLTS. WHEN I TRY AND CRANK AGAIN, STARTER WILL CLICK AND ALL POWER IN CAB WILL SHUTOFF FOR 15-20 SECONDS AND COME BACK ON. ANY HELP WOULD BE APPRECIATED.
Old 03-09-2005, 11:13 AM
kenyonja2007's Avatar
kenyonja2007 kenyonja2007 is offline
Send a message via AIM to kenyonja2007
Maybe the starter bearings or something in it s*1t the bed and it's taking a huge amount of amps from the battery to try to turn it over and that is why the voltage drops so much.
1994 Chevrolet S10
2.2L, 2WD, Auto, Long Bed, more here
Brakes are a good thing
Old 03-09-2005, 01:16 PM
OverBoardProject OverBoardProject is offline
Banned
Re: 1999 S10 2.2 Electrical Problem
Try a jump start. Even a battery showing 12 volts on a multi meter doesn't nessarily have the amps required to turn the starter.
