Go Back   Automotive Forums Car Chat > Mazda > MPV
Old 03-08-2005, 10:23 PM
In-the-dark In-the-dark is offline
Passenger side headlight problem (93 MPV)
I have lived with this for years, but I can't take no more. I need help, please! Every once in a while, the passenger side headlight used to dim for weeks at a time, and then it will recover by itself. This one time, it went totally out (or so dimmed that I cannot detect light). The problem only shows up when I turn on the headlight and in low beam. Daytime driving lighting is fine (i.e., not a burnt-out bulb). Turning on highbeam is fine. What could the problem be? Is this a DIY job?
CD.
Old 05-08-2005, 12:35 AM
itsme000 itsme000 is offline
Re: Passenger side headlight problem (93 MPV)
CD.
High beam and low beam have separate wire. Sounds like a relay or wiring problem. Inspect the socket carefully at the right side lamp. If it appears fine, check the relay.
