Old 03-08-2005, 10:10 PM
3.4grandam 3.4grandam is offline
Question performance chips
you know when you go onto ebay and you find those chips for like 10 bucks and they say the'll give you 15-20 hp and they are dyno proven. does anyone know if they accually work cause i was thinking of another performance mod for my 01 GA and i wasnt sure if chips accually work. if they do work can you explain to me how they work. i mean i just cant see gettin more HP out of alittle electronic device. well somone lemme know. thanx
Old 03-09-2005, 03:48 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: performance chips
The "chips" on ebay are nothing more then a mere resistor. The function of the resistor is this:
You unplug your IAT sensor, so it sets the default air temperature of the incoming air to 32 degrees F. This will dump more fuel then there is air for, causing your vehicle to run slightly richer in most cases, making about 1 to 2 HP at the most. However, if the temperature actually goes below 32 degrees, you'll be running lean, which kills performance and is dangerous for the engine. If it gets to warm outside, you'll be running too rich = lost power. (by the way, the resistor is their just to prevent a SES light from coming on by giving it a false signal). The resistor is all-around a bad idea. I tried on my 2001 GA, and in some cases I found my car was bogged down horribly. I saw essentially no gains from it - only a drop in gas mileage. I would greatly advise against doing the IAT resistor mod. If you decide you want to try it anyway, you can go buy one at radio shack for about 50 cents - same exact thing.
Ebay "chips" / resistors = suck and do more harm then good
DHP Reprogrammed PCM = good lol
Old 03-09-2005, 09:23 PM
thanx alot for that u definetly seem to no about these grand ams because you helped with another problem i had be4 so i think im gonna come to you if i need help haha thanx man
Old 03-10-2005, 05:15 AM
Ridenour's Avatar
GranddAmnit
LoL no problem man. I know about certain areas, but other areas I suck at . There's lots of great guys here on AF who will help you out - they're the guys that I learned everytthing from.
Welcome to the forum
