Old 03-08-2005, 10:02 PM
j_e_daly j_e_daly is offline
Test Power to 95 Silverado Radio
Everything in the dash is working except no power to the radio or clock. The fuse panel checks out ok. I've got the radio out and want to test voltage to the unit. Does anyone know which pin is the power?
Thanks, JD
Old 03-10-2005, 11:35 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Test Power to 95 Silverado Radio
I don't know right off hand, but you can find out pretty quick with a test light. Just ground it and poke the probe in all the holes. The one(s) that light it up is/are power.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
