Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 03-08-2005, 09:31 PM
street_racer_00's Avatar
street_racer_00 street_racer_00 is offline
Question A question
Well this doesn't really have to do with street racing, but you guys are smarter than most, so hear it goes. As you know, I've ordered a transmission cooler for my maxima...I went on Maxima.org and looked at a "how-to" for the installation...what this guy did was incorporated the STOCK tranny cooler by routing the return line from the stock one, then feeding it to the aftermarket one, then using YET ANOTHER return line from the aftermarket one to feed back to the transmission pan...I was like WTF, I thought the whole idea of getting a transmission cooler was to elimate the use of the OEM one completely...oh wait, this does have to do with street racing because I PURCHASED this product with saving my transmission when I street race in mind...but anyways, can anyone shed any light on this subject?
2000 Nissan Maxima SE, autotragic, sterling mist
My Max: Getting smoked by boosted cars since 2004
2004 AF award winner: longest time period w/o posting an actual street racing story
Originally Posted by CassiesMan
I got to see boobiues!
Old 03-08-2005, 09:40 PM
clawhammer's Avatar
clawhammer clawhammer is offline
Re: A question
I would just use the aftermarket one. Probably easier to install too.
Old 03-08-2005, 09:46 PM
Re: A question
That's what I was thinking...If I used the other guy's method, incorporating the OEM cooler with the aftermarket one, I'd have to buy extra lengths of hose and crap like that...I'm hoping that he was just making it more complicated than it actually is and that I won't fuck up my transmission if I just bypass the OEM cooler completely.
Old 03-08-2005, 09:51 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: A question
its better to use both transmission coolers. The factory one works, just not well enough, why wouldn't you add instead of subtracting and THEN adding? Also, you don't need any more hose, think about it.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 03-08-2005, 09:54 PM
CassiesMan's Avatar
CassiesMan CassiesMan is offline
AF Vendor
Send a message via AIM to CassiesMan
Re: A question
I have a novel idea...did it come with instructions? If so...READ THEM!
2006 Redline Red Nissan 350Z Base
K&N|Falken
I am just that JDM tight, yo.
Old 03-08-2005, 11:07 PM
Re: A question
It'll come tomorrow...and the guy said the factory hoses were useless because they were pre-bent and only conform to the OEM cooler...shit this is going to be a pain in the ass, isn't it?
Old 03-08-2005, 11:14 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: A question
use 'em both, the more the tranny fliud travles the cooler it gets. if you just use the aftermarket one it'll be like having the stock setup. the whole point is to add a second unit for the fluid to travel through. if you can, mount the new unit in front of your radiator for even better cooling. tranny fluid breaks down at 200 degrees, cooling it down'll keep your tranny running for longer.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 03-08-2005, 11:16 PM
Re: A question
Hey BP2k2MAX, you are an .org-er right? Read that mingo dude's write-up on the install of the tranny cooler, and explain to me in plain english what he is doing...because I got totally confused by his write-up.
Old 03-09-2005, 01:18 AM
BP2K2Max's Avatar
Re: A question
after you get the new tranny cooler set up with hoses, you remove the two radiator mount bolts and mount it to the front of the A/C condensor, right behind the bumper. you take off the radiator bolts so you can move it back and get your hands between it and the condensor to tie the zip ties.
the stock tranny cooler is on the bottom of the radiator. you leave the line going into the stock tranny cooler alone. run a new line coming out of the oem tranny cooler to the input on the new one you bought. you then put another piece of hose on the return end of the tranny cooler, and run that hose back to the the front/top of the tranny. then just tuck the hoses and zip tie them down in a couple spots.
BP's Rides;
Old 03-09-2005, 09:04 PM
Re: A question
Thank you...I was kind of thinking that's what he meant in so many words, but I needed some confirmation
P.S.: It came today, unfortunately I won't get a chance to install it until monday at the earliest, as that is the next day where I will have 3 consecutive hours of free time.
Old 03-09-2005, 09:14 PM
drdisque's Avatar
Re: A question
mine took me less than 2 hours and I had to improvise a way to cut the hose (i used a pocket knife)
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 03-09-2005, 10:24 PM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
I use both stock setup and aftermarket. It still won't let me hotlap more than 2 times though.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
