Old 03-08-2005, 10:14 PM
ct91rs ct91rs is offline
MAF test?
does anyone know if there is a way to test a Mass Airflow Sensor off a TPI?
Old 03-08-2005, 10:42 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: MAF test?
Is it setting a code for the MAF?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 03-08-2005, 11:01 PM
no code...yet. I'm still trying to get my car to run. Now it fires, but it won't stay running. The timing is close, and you can smell plenty of fuel, but after just a few seconds, it dies out. I'm running out of things that could be wrong, and it seems to be down to the MAF or the prom.
Old 03-09-2005, 12:23 AM
FormulaLT1's Avatar
Fight the powwa!!!
Re: MAF test?
Have you checked your IAC, TPS and idle screw?. Also I read this method in my service manual but never tried it. It says if you tap on the flat part of the MAF while the engine engine is running. If it stumbles or stalls it is faulty
Old 03-09-2005, 01:16 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: MAF test?
TPI doesnt have a maf.. they are speed density
Old 03-09-2005, 01:17 AM
FormulaLT1's Avatar
Fight the powwa!!!
Re: MAF test?
not true, early TPI's were MAF. I had 3 Vette's that were TPI and MAF.
John
Old 03-09-2005, 01:26 AM
DaMoNe6969's Avatar
Re: MAF test?
i stand corrected..
But if its the original motor in a 91' Camaro, it shouldnt have a MAF
Old 03-09-2005, 10:51 AM
motor is original, but the TPI is from an '86 Iroc.
Old 03-10-2005, 02:49 AM
Morley Morley is offline
The only "test" that would be meaningful for you is to start the car with the MAF plugged in and note how it runs. Nest shut it off and disconnect the MAF and start it up and note how it runs...if it runs better with it unplugged..suspect the MAF. Next hook the MAF back up and run the car again..wait for closed loop then gently rap on the MAF housing with a plastic screwdriver handle and see if the idle quality changes..if it does, replace the MAF.
