Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 03-08-2005, 07:59 PM
blkmonday's Avatar
blkmonday blkmonday is offline
fitting exhaust pipes
stupid question but i need a tip. i have a 66 olds im putting on a custom dual exhaust i had bent up from an online place. what is the best way to get the alluminum pipes to fit together (they are flanged and ready to bolt on) they wont slide into each other. i dont have a torch or a lift and my garage is very cold. any tips on how to get them together easily without heating them? the tollerance is to tight and probably shrunk after shipping. help...thanks in advance
Old 03-08-2005, 08:01 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: fitting exhaust pipes
http://www.harborfreight.com/cpi/cta...emnumber=37354 maybe?
-Mike
Old 03-09-2005, 07:06 AM
CraigFL's Avatar
CraigFL CraigFL is offline
Re: Re: fitting exhaust pipes
Originally Posted by GTmike400
I've never seen one of these that actually work unless the pipe is just very slightly deformed and just needs to be rounded. Usually the best of them(NOT Harbor Freight Tools!) can't really exert enough force to increase the diameter much at all. If you really wanted to do this, you would probably need a hydraulic powered version. Depending on what needs to be done, you may be better off filing the high spots with a half round file...
Old 03-09-2005, 11:40 AM
mike@af's Avatar
Re: Re: Re: fitting exhaust pipes
Yea, HF's stuff is pretty iffy. I've seen the hydraulic ones before, I definately wouldnt mind having one.
-Mike
Old 04-04-2005, 06:34 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
butt them together and brake out the welder....or find someone with a welder.
Just a regular old butt joint is the way to go.
hehe, I said butt
Old 04-04-2005, 06:58 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
just take it to a muffler shop and have them expand one of them. Like said above those rarely work, and to get enough force on it you have to clamp it down in a vice witch then squishes the other end.
Old 04-06-2005, 06:10 PM
99SilveradoGuy 99SilveradoGuy is offline
quickest way to do it is get the pipe in place and toss 2-3 tack around the tubes so it keeps in place then seal it up with a full weld , weld dont need to be to big considering it isnt load bearing. If you dont know how to weld thin aluminum like that without burning though take it down to a welding shop or muffler shop and have then do it. I usually just mig weld steel tubing up , ive never done an aluminum exhaust yet.
