Old 03-08-2005, 08:40 PM
caspere1946 caspere1946 is offline
blinkers too fast
1998 escorts blinkers are going too fast ,I've changed the flasher but it didn't help. Any sggestions?
Old 03-08-2005, 11:33 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: blinkers too fast
too much resistance somewhere. check the sockets for corrosion.
Old 03-09-2005, 08:07 PM
Re: Re: blinkers too fast
Thank you for the advice , as soon as the weather gets alittle warmer I will check them out and let you know the results.
Old 03-10-2005, 12:34 PM
DummyMechanic DummyMechanic is offline
I'm not familiar with "blinkers" and "flashers" but did you check to see if there is any blown signal light bulb?
Old 03-10-2005, 02:00 PM
A. Souphound A. Souphound is offline
My
1. Turn on your signal light/s and walk around the vehicle to see what bulbs are not working.
2. Some vehicles have two flasher units, one for turn signals the other for hazard flashers. Check both systems for comparision.
3. Alternator overcharging will cause a more rapid flasher rate.
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 03-10-2005, 08:45 PM
Davescort97 Davescort97 is offline
Escort guy
I experienced the same problem when one of my turn signal bulbs burned out. I replaced the bulb and the flashing returned to normal.
Old 03-12-2005, 04:14 PM
Originally Posted by A. Souphound
My
I found the problem today as I checked the front bulbs and found them to be fine. When I took the rear lens out of both sides(with some difficulty) I went to the auto parts store and bought four new bulbs and installed them. There was no corrision no where but the problem I found was that one of the prior owners installed a 3057 bulb instead of 3157! All the tail light bulbs should be 3157, dont mix bulbs or you will have problems like I had. Thanks to all you guys out there I've saved hundreds of dollars buy not haveing to take it to a repair shop. Thanks again. Cappy
Old 03-31-2005, 08:58 PM
FedEx Man FedEx Man is offline
Send a message via AIM to FedEx Man Send a message via Yahoo to FedEx Man
Well, let me ask you this: does only one side of the car blink fast or is it both sides? The reason I ask is if you r car originally requires HEAVY DUTY bulbs and you put in "regular" ones, the regular ones will flash faster than the heavy duty ones. The same is true for the opposite, if your car requires normal bulbs but you "accidentally" install heavy duty bulbs, the heavy duty bulbs will flash faster. This is due to less resistance inside the bulb.
Old 03-31-2005, 09:09 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
thats why i never assume and when asking this forum for help I alway go with the basics and open minded check of any suggestions in case i miss something. great to hear you figured it out
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
