Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-08-2005, 08:40 PM
Automation Automation is offline
Send a message via Yahoo to Automation
sohc to dohc engine swap
hello,
i got a 91 plymouth laser it has a single overhead cam engine, can i do a engine swap putting a dohc engine on it? do i need to change the transmission too? and any wirings or computer module to be change? driveshalf? thanks very much.......
Old 03-08-2005, 09:55 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: sohc to dohc engine swap
WELCOME TO AF.com!!!!!!
Have you tried doing a search on this topic?
I'll be nice ...unlike some others!!! Do a search first.
Just to sum it up for you.... From what I understand that type of swap is a bitch!!!
FYI... it's called a 420A to 4g63 swap.
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 03-08-2005, 10:19 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Re: sohc to dohc engine swap
lol you might change this but just in case you dont. its actually a 4g37 to 4g63T swap. yes it is a pain in the ass. some people say its easy but they never can prove how they did it and they usually end up being 12 year olds with too much time
check out vfaq.com but just to start you off you will need at the least.
engine
wiring harness
ecu
possibly trans
clutch
flywheel
starter
turbo
intercooler
intercooler piping
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-09-2005, 06:44 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
well I have a friend with a 92 laser and it came with a 4g63 so it couldnt be that bad and do u want aa turbo or NA
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 03-10-2005, 05:22 PM
Thanx 1stgenrocks... shows what I know!!!! lol
Old 03-14-2005, 09:04 PM
cjackson217 cjackson217 is offline
4g63 swap
i myself a 93 eclipse that has a 1.8 and i have another that has a 2.0 and i have an extra engine with turbo for both of them. in order to do the swap you need: the ecu for your engine(turbo ecu if you plan on putting in a turbo);new transmission (the number is f5m33); driveshafts; wiring harness; the gauge cluster is different (1.8 redline= 6,000 rpm / 2.0 redline= 7,000 rpm); starter; plug wires; distributor and cap:different fuses for certain things; and last, lots and lots of time and money if you want it done right. if you have any questions or need any parts let me know. You can instant message me at cjackson217 and i know a good bit about the d.s.m. mods
Old 07-13-2008, 06:44 AM
brandon356 brandon356 is offline
i have a 93 ecilpse 1.8 sohc i want to swap it to a 2.0 turbo dohc how hard is it to do
Old 07-13-2008, 12:25 PM
JScharF JScharF is offline
3 year old topic back from the dead haha.
Maybe searching isn't the answer. :P
1995 Mitsubishi Eclipse GS
Old 07-13-2008, 12:33 PM
steviek's Avatar
steviek steviek is offline
hard..
but its easy to revive old threads
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 07-13-2008, 12:42 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Just buy a turbo car if you want one.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-13-2008, 10:50 PM
if i am doing a 4g37 to a 4g63t motor swap if i buy 2.0 harness will it plug into the inner harness on my 1.8
Old 07-15-2008, 11:01 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Search. Now.
No more questions until you master Google, the 1000AAQ page, and VFAQ.com.
Kris
2012 Genesis Coupe 2.0t
