Old 03-08-2005, 07:39 PM
jeev07 jeev07 is offline
Clutch letting out 2 high
Hey guys is there anyway i can make my clutch let out lower because right now its letting out right at the very top and its kinda gettin to me. and while im talkin tranny, how do i loosen up my shifter, its a workout for my arms just gettin though the gears. oh and how do you know when your clutch is shot?? any help or tips appreciated
Old 03-08-2005, 08:26 PM
kingpinn's Avatar
kingpinn kingpinn is offline
Re: Clutch letting out 2 high
i think it might be shot how many miles are on it .
Old 03-08-2005, 08:37 PM
Scott82 Scott82 is offline
Ajdust you cable if you have cable tranny and see if that helps, and if ya feel froggy just put a stage 1 or 2 clutch kit in, you can get them for not too much more that a stock kit 50-70 bucks more or so depending on the brand. Any on have any luck with exedy clutch kits?
Old 03-08-2005, 09:07 PM
CR50HC CR50HC is offline
I would also adjust my clutch cable or better yet, try to replace it. They are fairly cheap. Made a world of difference on my 89 DX with 220,000 miles. Later on I did a motor swap but, the clutch cable did the trick.
Old 03-08-2005, 10:11 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Between The Batt. And The Engine At The Bottom Theres A Twist Knob The Clutch Cable Goes To. Couter Clock Wise Loosens It Etc.
Old 03-08-2005, 10:43 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
what kinda oil do you have in the tranny? If you have gear oil that may be why. Our trannys are stock with motor oil in them. I think 10w40 but im not sure. Alot of people put 85w gear oil in their trannys.
1991 Honda Civic DX Sedan
Old 03-09-2005, 09:05 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Re: Clutch letting out 2 high
Exedy Stage 1 "Street/Strip" d-series clutch kit is pretty sweet... along with ACT 11.9lb. flywheel, etc...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 03-09-2005, 06:33 PM
the twist knob; is it for the shifter? It has 185k kms on it. If i did go with a new clutch kit, would it improve the cars performance dramatically and how much would it cost to install?
Old 03-09-2005, 09:19 PM
Labor is free if u do it your self, haha if ya get a good kit look at spending 150-200 bucks. Labor would probably cost as much if not more than the amount of the clutch if you take it to a shop, depending on who ya know.
