Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-08-2005, 07:35 PM
hollmarkdude hollmarkdude is offline
Question D D D De Frost.
The switch for my fan is only working on the last two settings(breezy,hurricane). Is this an e-z fix or do I need a garage/dealership.
Old 03-09-2005, 05:58 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: D D D De Frost.
Replace the blower motor resistor and the fan will work fine. Usually located next to the fan motor. Costs vary between $20 and $40 depending on the dealership. Some of the aftermarket dealers are now carrying it too. You can change it yourself in about an hour with simple hand tools.
Old 03-18-2005, 01:23 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Re: D D D De Frost.
Just did it last weekend to my Daughter's car. Took a little over an hour to do. Removed the passenger seat so I could get up under the dash confortably. The part cost $28.00 at a local Car Quest, Auto Zone's supplier discontinued there's, and Advance auto parts needs 3 days to get the part shipped. The p/n generic number is RU44 (Advance Auto,Car Quest, Kragen, Parts America ).
You remove the lower dash panel cover (under the glove box), remove the blower fan(3 screws and a connector), then the resistance unit(2 screws and a connector). You will have to be quite nimble, almost a contortionist, to get at the back screw of the resistance unit, a long needle nose pliers did the trick for me.
