Hello I need some advice again.I have a 2000 Blazer 4x4.
The driver side disc needs to be replaced with a new one. Do I have to remove the 36 mm nut to do this?If not,how to I get the disc off.? |
Re: 2000 blazer front discs,need help again
Yes, and replace both discs , not just one side.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: Re: 2000 blazer front discs,need help again
ok,the 36 mm has to come off.What is the correct way to remove it
and install the nut,how many ft lbs to re torque. Do I brake it loose with the wheel on the ground,etc? |
Re: Re: Re: 2000 blazer front discs,need help again
Better yet, you should have a professional do this, you are just heading for trouble. That or buy a Haynes or Chilton's repair manual to help you.
Re: Re: Re: Re: 2000 blazer front discs,need help again
OK,why did 04Blazer say you dont have to take the 36mm nut off?
I have a Haynes manual and it does not show how to take off a front disk on a 4x4.Lets start over here. I jacked up 2000 4x4 Blazer (Front drivers side) I removed the tire I removed the claliper Now,does the disc assembly come off at this point or do I need to remove the 36MM nut?Thats all I want to know. |
Re: Re: Re: Re: Re: 2000 blazer front discs,need help again
Do Not Remove The 36mm Nut!!
1)remove the wheel (5 lug nuts) 2)remove the caliper (2 bolts aka guide pins) 3)remove the mounting bracket (2 bolts) 4) tap around the rotor (from the back) and it should come right off 5) clean the oil off the new rotors with some brake cleaner 6)put the new rotor on 7)bolt the mounting bracket back on 8)push the pistons back in and install the new pads 9) clean the caliper mounting bolts and lube them 10)mount the caliber 11)put the tire back on |
Thanks Will let you know how it goes.I am sick of paying repair shops
big money for brake jobs.The shop wanted over 700.00 for a complete brake job with new rotors no calipers.My total parts bill is just under 240.00 and a 100.00 for a good floor jack which will last a long time. |
Oh....don't forget to put anti-squel on the back of the new pads
