Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-08-2005, 05:24 PM
nathan865 nathan865 is offline
89 D150 Vacuum Hose Question
Need to know where fuel pressure regulator vacuum hose goes on 318 TBI(vacuum port)? was not connected when i bought it.
Old 03-08-2005, 10:22 PM
BamaDodgenMX's Avatar
BamaDodgenMX BamaDodgenMX is offline
Send a message via AIM to BamaDodgenMX Send a message via Yahoo to BamaDodgenMX
Re: 89 D150 Vacuum Hose Question
actually, there should be a daigram somewhere under the hood of the truck. unless the engine is not the original model, the wiring and hoses should be correct on the sheet. mine is on the underside of the hood, but i hear it's also been found elsewhere in the engine bay.
"I don't call it showing off or showing out... I call it you being mad because you can't do it!"
The '88 Project Pickup
Old 03-08-2005, 10:23 PM
and if all else fails, try the manual if you have it
Old 03-10-2005, 12:33 PM
diagram under hood did not show regulator.I don't have manual.
Old 03-13-2005, 07:43 PM
Oh.. thought you were lookin for the loc. of the hose.. I dunno about the actualy regulator, sorry.
Old 03-14-2005, 07:21 PM
thanks anyway.
Old 03-16-2005, 09:49 PM
dramey_2004 dramey_2004 is offline
fuel reglator
It dosn't mater what you have it hooked up to it you have to "t" off of another source of vacum as long as it is port vacum witch is what comes anywhere from below your carb. Just do that and then you can have some one shut off the engine and hear for vacum leaks witch someone proboly has done away with the old fiting and has it ran some where else
Old 03-19-2005, 05:52 PM
hippikess hippikess is offline
on the back of the TBI, next to the pressure regulator it a small tube that goes back into the TBI, not much vacum pressure to try to fool you into thinking that it goes someplace else. You'll need about 3 inches of hose. It goes from the pressure reg. to about an inch over, to the right looking at it from the front, and about a half an inche down
