Old 03-08-2005, 04:39 PM
gserve gserve is offline
idler arm
2000 Blazer LT 4 wheel drive. Just had state inspection today.Even though it passed the tech said that there was some "play" in it but met GM specs. So how expensive is this repair? I will probably not do it till needed.
Old 03-08-2005, 04:45 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: idler arm
Auto parts shop near me sells an OEM replacement idler pulley for about $9. The entire assebly with pulley is about $35. Your actual price may vary depending on location.
Old 03-08-2005, 04:50 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: idler arm
Idler arm, not pulley bro.
gserve, I suggest you get under your vehicle and grease the 11 grease fittings in your front end.
Here is a link to them:
http://www.automotiveforums.com/vbul...d.php?t=344505
Do NOT trust your lube shop to do them, they won't.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-08-2005, 04:53 PM
wolfox's Avatar
Re: idler arm
D-oh, my bad. Sorry, sorry... Stressful day at work. Teaches me to mix pleasure with work...
Old 03-08-2005, 05:08 PM
Re: idler arm
Thanks for the info. I'll be buying a grease gun!
Old 03-08-2005, 05:29 PM
zr2rando zr2rando is offline
Here's an example
I have a 95 S10 Blazer w/175k miles and just had the lower ball joints,idler arm,control arm,alignment,+tax done for total of about $630.
Idler arm,control arm parts and labor was about $207 of that.
Front end is lots tighter now..they told me that they had done well to last that long...yes...grease helps!
Rando
Old 03-08-2005, 07:30 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: idler arm
I Had front shocks alignment idler arm done for about 200 bucks. That was for my 91
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 03-08-2005, 08:23 PM
BlazerLT's Avatar
AF -Advisor
Re: idler arm
Grease every oil change, and do the greasing yourself.
Old 03-08-2005, 09:02 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: idler arm
It's a pretty easy fix.
I paid about $30 for mine and it took about 30 minutes to change out (that includes the time it took for me to stop and eat a slice of pizza and drink a beer.)
Old 03-08-2005, 10:20 PM
xero91 xero91 is offline
Re: Re: idler arm
BlazerLT im new to this whole scene. What are grease zerk's, how do I grease them and what do I use?
Thanks in advance
Old 03-09-2005, 12:25 AM
BlazerLT's Avatar
AF -Advisor
Re: idler arm
Grease zercs are the grease fittings that you attach a grease gun too.
Old 03-09-2005, 12:32 AM
Officer Redneck's Avatar
Officer Redneck Officer Redneck is offline
Send a message via MSN to Officer Redneck
Re: Re: Re: idler arm
Thanks in advance
Howdy, welcome to the forum. I'm not BlazerLT but I can help. Grease zerks look like little nipples. First, go to a parts store and buy a grease gun, they can tell you what kind of grease to get. Jack your truck up and put it on jackstands, look for all the zerks (I think there are 11 but not positive) push the end of the hose onto the zerk and pump slowly untill there is a change in the pressure on the handle. If grease starts to come out STOP IMMEDIATLY!!! Some parts have a rubber seal and if you put to much grease in it, it will blow the seal. As a side note, buy a Haynes manual they help alot in finding things. Good luck.
2003 Honda Element EX
2002 Kia Spectra (can't "Improve" or wife will kill me)
1986 Dodge Ramcharger (For sale with a 1966 Rambler 660 classic to boot)
" Idon't know how many of them it would've taken to whoop my ass, but I knew how many they were gonna use. Thats a handy little piece of information to have right there." "Ron White"
http://www.myspace.com/officer_redneck
Old 03-09-2005, 12:37 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: idler arm
You don't need jack stands to grease out truck's front ends.
I would have someone show you how to do it first, invite someone over to show you how to do it and when to stop pumping. Over doing it and pumping too much grease in could ruin your front components.
Old 03-09-2005, 01:06 AM
Re: Re: Re: Re: Re: idler arm
If you are as big as I am, you would.
Old 03-09-2005, 02:45 AM
BlazerLT's Avatar
AF -Advisor
Re: idler arm
point taken
