front spring lift
I know there have been alot of people asking about suspension lifts already but I have already purchaced 2.5" lift springs for the front.
After I had recieved them is when I was told it was "recomended" to replace the upper A-arms with 2.5 or taller lifts. Can anyone tell me if I accually need to replace them or not. Ofcourse I know I'll need to get an alignment after I install the springs. Also, with 2.5" lift in the front, what size block to I need to go with in the rear to level out the truck. 1.... 1.5..... 2 ? Thanks.
![]() 2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything! 84k miles/30NOV11 Yeasu 857D/ATAS-120A - "When all else fails..." |
Re: front spring lift
What are you lifting? Unless its a 2wd you can't lift with lift springs. As for the block, I'd say use 1 or 1.5" block.
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
I'm lifting an '01 2wd.
