Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-08-2005, 04:14 PM
jwolfer jwolfer is offline
Send a message via AIM to jwolfer
Unhappy 1998 Ford Ranger EVAP CODE BLUES
I have a 1998 Ford Ranger with dtc p0453 replaced pressure sensor in tank and still same code Can anyone help me.....
Old 03-11-2005, 09:05 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
Re: 1998 Ford Ranger EVAP CODE BLUES
thereis no 453 code. there is a 443 witch i had and it was the diafram on the evap valve on drivers side fender. start from the engine with a can of carb cleaner spraying around vacume hoses and valves they connect to till motor revs up then you found your leak. the 443 code is a gross vacume leak somewhere.
Old 03-11-2005, 09:48 AM
Re: Re: 1998 Ford Ranger EVAP CODE BLUES
There is a code 453, it is not very common, has to do with the FTP Sensor in the tank.. Found the problem was bad PCM Thanks for your help. I new the 443 code repairs the 453 through me!!!!!
Old 03-11-2005, 10:21 AM
2000mudder's Avatar
sorry. i never seen that code anywhere. did u get your prob fixed?
Old 03-11-2005, 10:40 AM
yes bad computer(PCM)..
