95 Transport
Strange thing just happened yesterday when driving at 90-100 kms. If you press the gas pedal it seems to feel like the engine if jerking or not getting enough fuel.
Any suggestions? New spark plugs? Thanks |
Re: 95 Transport
When mine started that show, trying to overtake was a real challenge....
I would be told it is the fuel pump,the fuel filter, the ignition pack....! While all of the above could have been possible, that was none of that stuff. In fact, I found the MAF sensor to be dirty: www.avigex.ca/xport/maf.jpg the key element is a small shiny wire across the intake throat and that was covered by kind of gray claylike material . (my fault: had run it without an air filter for a little while) Used Q tip or artist paintbrush with alcohol to clean it up and all returned to normal. Cleaning it will cost nothing but 2 drops of alcohol . If not that, will check for something else later. HOwever, if you can have solid acceleration as soon as you depress throttle, then check that thread: http://www.automotiveforums.com/vbul...d.php?t=375933
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
