Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 03-08-2005, 03:25 PM
silvrrunningwlf silvrrunningwlf is offline
Send a message via AIM to silvrrunningwlf
Question Power Steering Pump Problem
I think my power steering pump has gone out although i'm sure how to tell... my steering it extremely tight and i can barely turn my car.. there doesn't seem to be any odd noises. if someone can help me out with this it would be great!
Old 03-08-2005, 03:45 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Power Steering Pump Problem
It may just need to have the belt tightened. It could also just be low on fluid.
Old 03-09-2005, 12:51 AM
the fluid level is fine, it's completely full.. that's the first thing i checked... i really hope it's just a belt
Old 03-09-2005, 07:32 AM
Fractured1 Fractured1 is offline
could be several things..your valves in your rack could be sticking...bad pump...clogged filter...does it do it once the car warms up...if its only tight when cold I would lean towards your rack...let me know about the cold issue and I will tell you haw to flush it to "maybe" correct this issue
Old 03-09-2005, 06:13 PM
it's still tight once warmed up... i don't know if it has anything to do with my steering problem but the front driver side wheel, even before all this steering stuff happened, was making a grinding noise, kinda like the brakes rubbing against rotors would sound... i don't know if the brakes are going bad or if it's the joint or if it might have something to do with the steering but it's still making the noise.
