Old 03-08-2005, 02:32 PM
Scjar Scjar is offline
Twin Turbo question
I read one post saying that it wouldn't be worth putting a twin turbo on a GS-T Eclipse. What should I do if I have a 98 GS? I'm wanting to put at least one turbo, and I was thinking about twin tubros, but if its not going to help any, ill just go one big one. Thanks in advance.
Old 03-08-2005, 02:39 PM
--- --- is offline
Re: Twin Turbo question
Put a Hahn turbo on it or buy a GS-T/GSX/TSi
I drive a slow car.
Old 03-08-2005, 03:01 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
its pretty pointless to twin turbo a 4 cylinder.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 03-08-2005, 03:46 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
half of the reason is because it's cheaper and faster to do a single turbo on an already single car. the other half is because the design is inefficient and our engines aren't big enough to support 2 turbos. Both reasons apply.. no, it wont be any better or cheaper.
Old 03-08-2005, 04:25 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
Even if you were to use two t-25's, the 2 liter displacement would have a hard time spooling them both. Thus, insane turbo lag.
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 03-08-2005, 07:44 PM
AngelOfNight 9's Avatar
AngelOfNight 9 AngelOfNight 9 is offline
If you're not changing your 420A internals then I would just go with a kit using a 14B, change your fuel pump, injectors, 3 inch exhaust, get your ECU programed, better flowing intake and better cooling fans with a cooler thermostat. Good intercooler & synthetic fluids for heat reduction and less friction & etc. Don't have to go crazy but we all know the more air we push into our motor the more fuel we need and a bigger exhaust for the motor to breath. If you have enough money to spend then go with a *dual ball-bearing turbo* for quicker spool thus less turbo lag. Venom has a good cheap set of injectors that produce 10% more fuel than stock if you're not going all out.
*91 TSI AWD*
Old 03-09-2005, 10:24 AM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
Re: Re: Twin Turbo question
I was wondering that you people say its pointless for a twin turbo on a 2.0 liter, so wouldn it be pointless on a rx-7 that has a 1.3 twin turbo???
So I dont get that??????
Old 03-09-2005, 12:17 PM
drdisque's Avatar
you can't compare the displacement of rotaries to the displacement of piston engines. remember that in a rotary that displacement is making power all the time and in a piston engine its only making power at most half of the time.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 03-09-2005, 08:20 PM
kjewer1 kjewer1 is offline
AF - Advisor
Excellent reply! Its a common comparison, but its appels to oranges. Not many poeple understand why.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
