Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 03-08-2005, 01:43 PM
DetroitMuscle15 DetroitMuscle15 is offline
Banned
Safe Nitrous level??
Iam getting a 99+ Mustang GT in a few months and i cant spend big on mods.......I can spend a few here and there for minor bolt-ons but i want Nitrous.....Will it be safe and will my engine last long if i got a 125 shot kit or should i keep it low because i dont want my to shorten my engine life that much
Old 03-08-2005, 02:47 PM
dampachi's Avatar
dampachi dampachi is offline
Banned
Send a message via AIM to dampachi Send a message via MSN to dampachi Send a message via Yahoo to dampachi
Re: Safe Nitrous level??
Only 125hp shot? Go all out and get a 400hp shot! Your motor can handle it no problem. Launch at 5k rpms..and as soon as you drop the clutch..spray your nawzzzzz!
Old 03-08-2005, 03:35 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
I am with dampachi, why limit yourself
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 03-08-2005, 04:02 PM
HighRev87's Avatar
HighRev87 HighRev87 is offline
Banned
ahahhahaha....ehhh.....ahhahahhaha.
Yea the mustang's engine is virtually indestructable (unless you dont add water to your gas tank then it will blow.)
In my suggestion: Buy 3 125 kits, so you have a 375 shot (400 might be pushing the indestrucatble motor) and add some hot water to your gas tank before going out. Should be good for about 660rwhp, unless you use water + salt in tank, then about 760rwhp.
Old 03-08-2005, 04:26 PM
SkylineUSA's Avatar
Go with a 50 shot, and jet your way up. Every 50, retard 1*.
Old 03-08-2005, 04:36 PM
Banned
common guys be serious..............Id figure since Dampachis gonna have around 350-400HP...a nice 125 shot of Nitrous will at least enable me to pace him for a few seconds
Old 03-08-2005, 06:29 PM
HighRev87's Avatar
Banned
Re: Re: Safe Nitrous level??
125 is safe. 150 can be done but is pushing it. Both need a tune. However, he would beat you with either.
Old 03-08-2005, 06:30 PM
eillob's Avatar
eillob eillob is offline
I think you'll be very safe with a 125 shot. 150 is about as high as I would push it, and stay away from the wet kits stick with the dry shots.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 03-08-2005, 07:04 PM
HighRev87's Avatar
Banned
I would beg to differ. From the research I did when I considered spray, alot more problems come from dry kits then wet. Also, with recent growing technology from high end companies (such as NOS), wet-nozzles are more preventative to "puddle-ing" then the older wet kits were (which is why most shyed from them)
Old 03-08-2005, 07:05 PM
noctorum noctorum is offline
Why?
Old 03-08-2005, 07:27 PM
dampachi's Avatar
Banned
If you ran drag radials..and a 150hp shot..And you had a good launch and then used your nitrous..you may be able to pull ahead until I get traction. I will be running street tires..possibly nitto 555s.
Old 03-08-2005, 07:28 PM
HighRev87's Avatar
Banned
Originally Posted by noctorum
Why?
why what?
why 125 is safe? That is a modest amount to run without putting to much wear on the engine.
why 150 max? It is probally about the highest level you can do without running into major internal problems.
why dry kit? Matter of opinion.
Old 03-08-2005, 07:49 PM
Re: Re: Re: Safe Nitrous level??
Originally Posted by HighRev87
why what?
Why dry kit
I thought wet was safer?
Old 03-08-2005, 08:08 PM
Banned
Yeah iam definitly gonna consider a 125 shot. i will be puttin around 380HP and iam "decent" at launching but i probally wont be usin drag radials so once Tim gets traction im toast.....oh well
Old 03-08-2005, 08:31 PM
HighRev87's Avatar
Banned
at the wheels? No...
The 99+ Gts are rated at 260hp (03-04 might be like 265), but that is at the crank, at the wheels you can look forward to drivetrain loss.
