Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-08-2005, 12:24 PM
Duncan1 Duncan1 is offline
digital speedometer on 95 sedan
The digital readout for speed, miles etc on my 95 caprice is acting up. Sometimes it works fine and is really bright, sometime it's gone completely, sometimes really dim. I played with the dimmer switch but that doesn't change anything. Anybody have a clue? Thanks!
Old 03-09-2005, 03:33 PM
B33p3r B33p3r is offline
I had a caprice that did the same thing. The display module was electrically connected to the instrument panel with spring loaded metal connectors. They didn't actually have springs, but they are shaped such that they press against the panel terminals. take the module off the instrument panel and you'll see what I mean. Just pry these contacts out a little very gently. They'll reseat and you'll be good for a while. I had to do it once a year or so.
Old 03-10-2005, 05:38 AM
Re: digital speedometer on 95 sedan
Thanks for the info. How do you take the module off the panel without using a chainsaw??
Old 03-12-2005, 10:58 AM
2fast4me 2fast4me is offline
Same thing here on my '94. I've heard a myriad of things to do, from replacement, to cleaning, and most often, simply removing and resoldering all the connections. I haven't tried yet. My speedo is usually what goes out at times, but I always have my tripodometer working, it's just the total mileage and speed that usually wigs out on me. That's why I have an aftermarket tach, so I can judge my speed.
Old 03-17-2005, 08:02 AM
It's been a while since I had that vehicle, if I remember correctly it either pulled right off or a couple screws holding it. Take a good look and you'll see.
Old 03-17-2005, 08:54 PM
please do it for me, LOL. what a pain in the ass PITA!
Old 03-19-2005, 12:34 AM
LTZ9C1 LTZ9C1 is offline
Heres a pretty good site that explains how to dismantle and clean your digital speedo, it worked for many, it may work for you
http://members.aol.com/RCAPSS/fix.htm
Old 07-07-2005, 11:07 PM
Jamison350 Jamison350 is offline
LTZ9C1, thanks for that site. I did some investigating and it payed off.
Thats one killer right up that Howie Hoffman did. Could he be any more detailed? Special Thanks to Howie. :
"A drop of honey catches more flys then a gallon of gail" --Abe Lincoln
Old 07-08-2005, 07:58 PM
radioman2002 radioman2002 is offline
I was actually able to do it in about an hour, also I wouldn't pry anything, they are liable to break, you can clean the contacts and the connections on the instument cluster with rubbing alcohol and a Q tip, or a good electronic contact cleaner. I put dielectric silicon grease on both before re-assembly, to prevent any further corrosion.
Old 07-09-2005, 10:04 AM
Incitatus's Avatar
Incitatus Incitatus is offline
Re: Re: digital speedometer on 95 sedan
That's the most common repair for that problem. Some guys have gotten good at it and do it on the side for other guys.
Try to find somebody like that. Do a search on some of the other B-body forums (impalassforum, 4adrive, etc) and see if you can find someone in your area.
A big fan of the big sedan.
Old 07-09-2005, 10:35 AM
Incitatus's Avatar
See if this is of any help.
