Air Conditioning
My 93 full size blazer's AC did not work when I turned it on for the first time since last fall. The compressor is not coming on. both fuses are good. I have a wiring diagram that shows a relay, but does not say where it is located. I think I have an electrical problem becaue I cannot hear or "feel" the compressor. The hose feel test does not indicate a bad compressor. My system is still R12. Any help appreciated.
Re: Air Conditioning
have you tested the pressure?
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
On my 96 there are three relays bolted to the firewall for AC. You may want to check there.
Since you probably can't go out and buy a 1lb. can any more, you will probably need to take it in somewhere and have the pressure checked and will probably need the system re-charged. The trick is to try to locate the source of the leak before you loose any more freon so you don't have to keep recharging it. At $90 per pound, you want to find and correct the leak.
Re: Re: Air Conditioning
Rick, I had no idea that the refrigerant level could be so low as to keep the compressor from kicking on. What you say is probably true, because I don't think it was cooling all that well last summer, although it did work. That's what happens when 2 people have 6 cars. This makes the 2nd one with no AC right now. The other was obviously low in a non closed system. The good news is that from your reply it sounds like I can still get R12. I thought I would have to convert to r34 to fix it if the freon was low. I still have one of those hoses that was used to put the little cans in with. is there any safe way to test the pressure or lack therof with the hose and clamp? There is a pretty honest mechanic close by that has treated me well before with this Blazer, so I will just take it to him I guess. It has 190k miles and I don't believe the freon has been recharged but once many moons ago. |
Understand that if you continue to use R12 that stuff is expensive (40 bux an ounce) and your system holds 14 ounces.... You've obviously have a leak somewhere which really needs to be addressed. If you want to check the pressure go to advance autoparts (or any parts store) you can get an ac pressure gauge for 10 bux that will give you an indication of how low you are. That said, you need to find the leak. Once you find the leak, you should convert to r134 (or even Hot Shot (check with any local HVAC outfit, it's compatible with your r12 oil and much cheaper and cools better) But your leak really needs to be fixed...
Re: Re: Re: Air Conditioning
My last truck had the same problem. I bought a conversion kit for Wally World for about $27.00 and it came with a gauge, a can of freon that had a type of stop leak and oil already in it and a second can of freon/oil by itself. It was pretty easy it do and it worked for two years before I had to add a can of R134 but at $4.96 a can I could live with that. Just a suggestion, take it how you will.
2003 Honda Element EX 2002 Kia Spectra (can't "Improve" or wife will kill me) 1986 Dodge Ramcharger (For sale with a 1966 Rambler 660 classic to boot) ![]() " Idon't know how many of them it would've taken to whoop my ass, but I knew how many they were gonna use. Thats a handy little piece of information to have right there." "Ron White" http://www.myspace.com/officer_redneck |
