Old 03-08-2005, 11:45 AM
biglogonafrogbig biglogonafrogbig is offline
Transmission Slip
I don't know if any of you have a pepboys near where you live or have been to one but they have this one product that is supposed to stop transmission slipping it says just to add it in but i was wondering if it actually worked also what are some of the signs that your transmission is going out its kind of shifting hard and doing some weird shifting when i bought the truck the guy said that the guy he bought it from had already replaced it but he didn't know when is there anything you can add to it to help its life out any info on this would be appreciated thanks in advance for the posts
Old 03-08-2005, 11:48 AM
heres a link to it'
http://www.eliteone.com/lucas/trans.htm
Old 03-08-2005, 12:13 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Transmission Slip
Most additives work very well on some vehicles, and hardly at all on others. Since it's only $10, you may as well try it.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-08-2005, 12:14 PM
J-Ri's Avatar
Also, it depends on why it's slipping. If you have worn clutch packs or bands, it probably won't do anything.
Old 03-08-2005, 04:45 PM
broughy84's Avatar
broughy84 broughy84 is offline
if this doesn't work, give it a cap full of brake fluid. Not TO Much, just one. It will swell everything in the tranny up making it last a little longer. I did this on mine to make the 700r4 last a little longer!
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
